Old 19th Jun 2019, 10:32 am   #21
MrBungle
MrBungle's Avatar
Default Re: Fluke 8010A digital multimeter
Yes I'd take the changeover switches over rotary ones any day. You can still get replacements for the Fluke ones if you need them as well as they are standard parts. Rotary switches seem to be pretty much dead now.
MrBungle is offline
Old 20th Jun 2019, 2:45 pm   #22
Techman
Techman's Avatar
Yes, it had occurred to me that as it's a true RMS reading meter that perhaps I shouldn't try to adjust the AC ranges, but I think the whole thing was out anyway and had probably been adjusted in its past life anyway, knowing where it came from. Perhaps I could use the amplified output of an AF signal generator?
Techman is offline
Old 20th Jun 2019, 2:48 pm   #23
MrBungle
MrBungle's Avatar
As the ranges are consistent I tend to use an AWG to check mine. I connect the 34401A up to it, set the AWG on full whack amplitude at 1KHz and then check the rest against that meter.
AF generator should be fine as long as it has stable amplitude.
MrBungle is offline
