Old 9th May 2019, 1:02 pm   #2161
Sinewave
Sinewave's Avatar
Default Re: AVO Multimeter survey
What are the different variants? I can only off the top of my head think of 5.
Sinewave is offline   Reply With Quote
Old 9th May 2019, 1:10 pm   #2162
AndyGilham
Actually, the differences I have seen are only related to the top resistance board (Or Volt former board). From early models with just wound shunts, then hand wound resistors and the introduction of wound coils in various combination and then the resistors......it just goes on!
Andy
AndyGilham is offline   Reply With Quote
Old 9th May 2019, 3:03 pm   #2163
Sinewave
Sinewave's Avatar
I see, so not variants as such, just different components used from time to time?
Old 9th May 2019, 7:50 pm   #2164
The Philpott
The Philpott's Avatar
Andy, I now recall i posted details of Meter 769-2929 on the survey thread, starting at Page 72, Post No.1438 onwards. These notes are preferable to the handwritten ones, which are a bit muddled. (searching on 769-2929 i the quickest way to access it i imagine)
The peg at the rear of the early type nickel plated Z screw appears to be glass, i assume this is to prevent touching the screw with a finger affecting the needle deflection. It does look a bit fragile though, replacing the movement is delicate!
Dave
Old 9th May 2019, 11:27 pm   #2165
sven_swe
sven_swe's Avatar
New unit:
AVO 8 MK5
No 0547746CE 7/84
sven_swe is offline   Reply With Quote
Old 13th May 2019, 7:00 am   #2166
AndyGilham
Thank you Dave, I shall compare your detailed notes with my instrument.
Andy
Old 18th May 2019, 11:51 am   #2167
M0XNA Neil
Acquired two AVO9 SX's and both with cases with serial numbers:
5222-1S-263 which will be February 1963.
5573-1S-163 which will be January 1963.
Both are still accurate and look as if they have never been used out of their cases.
Neil
An engineer makes for a penny what a scientist makes for a pound!
M0XNA Neil is offline   Reply With Quote
Old 5th Jun 2019, 2:16 pm   #2168
Superscope
Multimeter Survey 3rd Edition.
Finally got round to finishing this Edition of the Multimeter Survey.
Thanks to everybody still contributing Numbers and Information.
A little behind schedule, but have had very little Time recently to spend
on this, but it's ready now.
I'm trying to make it a bit more interesting and informative than simply a
long list of Numbers and this is the first attempt at expanding it's scope
some what. It is significantly updated from the previous Edition.
Comments and suggestions most welcome as always.
Hope the Forum find this useful or informative.
Ian
Superscope is offline   Reply With Quote
Old 5th Jun 2019, 2:40 pm   #2169
pmmunro
Ian,
Very many thanks for the work you have done on this survey. Even at a quick assessment it makes very interesting reading and I can see that I have a few numbers I should be contributing.
PMM
pmmunro is offline   Reply With Quote
Old 5th Jun 2019, 4:47 pm   #2170
vidjoman
I have an AVO 8 MkIII serial no. 67186-1067.
An AVO 9SX but only number on the dial says Meter Type 12889.
Also an AVO Multiminor Mk5 stamped into the dial 27363
vidjoman is offline   Reply With Quote
Old 5th Jun 2019, 11:06 pm   #2171
Pamphonica
Pamphonica's Avatar
Noble work Ian. Steve (SPCh) would have been so pleased that all this data was finally captured for posterity.
Thanks you for this very thorough effort.
-Jeremy
Pamphonica is offline   Reply With Quote
Old 7th Jun 2019, 7:06 pm   #2172
Superscope
Please find attached an update to the Model 40 Data.
I don't know if anybody actually uses the Survey Data, but I
use it occasionally and noticed the Model 40, 47A Data ect wasn't
sorted correctly, so the Years were a bit jumbled about.
So I have reproduced the Model 40 Data here as an update.
For the future, I have also removed a number of entries where Meters
had no Serial Numbers logged as it seemed a bit pointless having them
included.
Sorry for any inconvenience
Ian
File Type: pdf AVO Multimeter Survey 3rd Edition Model 40 update.pdf (182.1 KB, 97 views)
Old 13th Jun 2019, 6:59 pm   #2173
The Philpott
Thanks for your efforts Ian.
It may be of interest to note that an Avominor Type E testmeter has just come up for sale elsewhere, s/n E157-1954, indicating that the Type E was still being made in 1954. (It also supports my assertion that more than one sequence of serial numbers was allocated to the 'E', No.157 being an unsuitably low number for a meter that had been in production for 14 years!)
This meter is highly likely to have the additional back-board inside, loaded with component resistors. (Good longevity but poor access until the board is removed.)
Also of interest is a RAF label announcing that the meter requires attention but is repairable- either by an approved RAF facility or an approved outside contractor. The fault mentioned is an error of 2% on the 20mA range- and the date on the label is 1970.
Yet another piece of WW2 spec equipment that the RAF carried on using for quite some time, then.. The generation of a repair request on the basis of a 2% error seems excessive to me - (on such a small meter.)
Dave
Old 13th Jun 2019, 7:09 pm   #2174
Sinewave
Sinewave's Avatar
That baffled me too, especially considering the accuracy at FSD as it is anyway!
Old 16th Jun 2019, 9:28 pm   #2175
Sinewave
Sinewave's Avatar
Silly question here, but the survey is just for Avo multi-meters isn't? Should I add All Wave Oscillators etc?
Old 16th Jun 2019, 10:02 pm   #2176
Murphy Maniac
Murphy Maniac's Avatar
I may have 'missed the boat' for the survey, but for the sake of completion of your records, the AVO meters which I have in use are as follows:
Model 8 Mark III 22984.865
Model 7 11380-A-949
Model 8 Mark II 6555.C.1163.D (in green plastic case)
Model 8 Mark IV 64396 (in leather case)
Congratulations on completing such an epic task.
Best Wishes.
Geoff. (BVWS Member)
Murphy Maniac is offline   Reply With Quote
Old 16th Jun 2019, 10:36 pm   #2177
Sinewave
Sinewave's Avatar
Good job Ian,
What I'll do is go through this document and see which meters of mine aren't in it, then add mine to the thread. This may take me some time though
Old 17th Jun 2019, 3:41 pm   #2178
Sinewave
Sinewave's Avatar
In the order of which the model sections are listed within Superscope's PDF document, here are some serial numbers to add for the next revision of the survey. Some of this has been in my collection for some time, some have been within the past year.
  • 36 Range Model 5 - Serial from meter movement No. 104-3168
  • Model 7 Mk 1. Serial from movement scale No. 39538-A-253
  • Model 7 Mk 1. Serial from movement scale - No. 7345-20711
  • Model 7 Mk 1. Serial from movement scale - No. 71045-11405
  • Model 7 Mk 2. Serial from side sticker - 11492 7/6/76
  • Model 7x Panclimatic. Serial from movement scale - No. 90863-A-563
  • Model 40 Mk 1. Serial from movement scale - No. 9236-B-953
  • Model 40 Mk 1. Serial from movement scale - No. 5682-B-651
  • Model 40 Mk 1. Serial from movement scale - No. 2177-B-1148
  • Model 40 Mk 1. Serial from movement scale - No. 404178-443
  • Model 40 Mk 1. Serial from movement scale - No. 7818-B-1152
  • Model 40 Mk 2. Serial from side sticker - 81583 40/2/73
  • Model 40 Mk 2. Serial from movement scale - No. 24747-B-464
  • Model 40 Mk 2. Serial from movement scale - No. 310-B-661F
  • Model 40 Mk 2. Serial from movement scale - No. 17267-B-159
With one revision as follows;
Model 7 Mk 2 listed as 3922, I had made an error, the serial is in fact 39222. Serial from sticker on the side, date 4/71.
Old 17th Jun 2019, 8:55 pm   #2179
Superscope
Murphy Maniac
Geoff, you certainly haven't missed the Boat!
This is an on going Project and hopefully will
continue for quite some time.
Thanks for the Numbers.
Sinewave
Again thanks for your Numbers and the useful addition of
where the Numbers were situated.
The introduction of the Label showing the Serial Number
instead of the Scaleplate seems, from the Data so collected,
to have started around March/April 1970.
Previously, I had only been logging AVO 8/9 Mk IV Serial locations,
and that is where the Date estimate is derived from.
This information is not currently shown on the Survey Document though.
But I have recently started to log Model 7 and 40's as well when identified.
Currently, I assume all AVO Meters would have started using
the Labels at the same time.
We may be able to narrow this Date down further if that information is provided
like you have done.
Regarding the addition of "All Wave Oscillators", the Survey
started off as a Multimeter only Survey, but I see no reason why
it shouldn't include other AVO products.
I have no problem including Data for other AVO products, if
that is what the Forum wants.
Comments on this are invited!
Ian
Old 18th Jun 2019, 6:17 pm   #2180
Sinewave
Sinewave's Avatar
Ian, glad to be of assistance to this fantastic effort.
In fact from my list here and my own spreadsheet of my collection, it appears I do have Model 7's from the 1940's which I didn't think I had. I have collected so many over the years that I can't remember what I have!
In future revisions, would the likes of the Precision Avometer be entered into the Specialist section of the survey?
Aslo I'm wondering, would you see there being any value in entries detailing the presence of the PF sockets for the mk 1 models 7 and 40?
