Old 14th Sep 2018, 2:42 pm   #121
theredhouseinn
theredhouseinn's Avatar
Default Re: Mullard Valve Tester Card Project
Hi Stan
My missing card numbers.
18,24,28,29,40,70,71,73,76,84,87,232,240,250,252,3 42,3511,375,410,428,430,459,481,482,483,503,557,58 8,602-609,644,647,648,651,652,662,664-668,673-705,715,716,718,721-753,761-786,797-928,948,952-956,9611,962,964,968-975,979,980,981,983-995,1003-1017,1020,1021,1023,1027-1054,1056,1062-1103,11106,1107,1117,4420,1122,1123,1124,1126,1129 ,1133,1137,1138,1142,1145,1147,1150,1151,1152,1154 ,1155,1160,1160,1165,1173,1174,1182,1197.
that's the lot Stan. I used the Mullard numerical list to check my cards. Where I have grouped numbers I have probably included non-issue card numbers. Appologies for this.
My email address is - [REMOVED BY MODERATOR,SHARE BY PM] - I didn't realise that I had so many cards missing, if it is easier for you to email me the file, please do so.
Incidentally, since my complete refurbishment of my tester, it appears to be working perfectly on the valves tested so far.
John.
Last edited by Paul Stenning; 14th Sep 2018 at 3:18 pm. Reason: Removed email address
theredhouseinn is offline   Reply With Quote
Old 14th Sep 2018, 5:43 pm   #122
Electrical
Electrical's Avatar
Hello John
I have just finished rescanning the images you sent and I have converted them to pdf files, please see attachment.
I will check and see if I have all the cards you have requested and I will ask one of the moderators if I can post the files on the forum or if they would prefer I sent them by email. I will send you a Private Message (PM) when I have collected all the data and let you know the best way to send it.
Regards Stan.
Junk accumulates to fill the space available.
Electrical is offline   Reply With Quote
