16th Mar 2023, 2:06 pm | #1 |
Roband Varex 60-5 power supply
Gentlemen and Ladies,
I hope you can assist me with sourcing some new indicators for my Roband Varex 60-5 twin power supply. I need the lamp holder assembly as the ones I have have gone open circuit. I have done a quick search on the internet, to no avail. All that the manual states is SIGNAL LAMP D23/RED D23/WHITE. Any help would be much appreciated. |
16th Mar 2023, 2:30 pm | #2 |
Re: Roband Varex 60-5 power supply
Does you Roband use this style lamp (wrong colours I know )
Cheers Mike T
18th Mar 2023, 6:25 pm | #3 |
No, unfortunately not.
I should have attached photos on my first post. The lamp is an E5/LES, but the holder is very specific for the front panel bezel. The problem is the outer case screw thread doesn't make contact with the solder tag. I've tried 'massaging' them, but to no avail. |
