29th Jul 2021, 12:29 pm | #1 |
Adjusting tracking weight on a Philips AG1014 / Disc Jockey
Hello everyone
Is it possible to adjust the tracking weight on a Philips AG1014? I'm (obviously) trying to lighten it. Would be good if there was some proper adjuster, but if not thinking of Heath Robinson type ideas namely, use a stronger spring at back of the arm or alternatively adding some weight on the arm beyond the pivot point (FYI there's not a lot of overhang on these arms back there!) Any ideas? thanks Joe |
29th Jul 2021, 12:54 pm | #2 |
Re: adjusting tracking weight on a Philips AG1014 / Disc Jockey
I may be wrong, but this generation of Philips autochangers were expressly designed to be used with only that Philips head, i don't think any form of optional adjustment is provided. Others may know more. I agree about the lack of overhang and this makes adding more weight difficult.
Edward. |
29th Jul 2021, 6:15 pm | #3 |
At the very back of the "ball" end of the pickup arm, there is a hole which has a screw in the bottom. This is connected to a small bracket, connected to a spring. Turning tha screw adjusts the weight, but you need a very fine screwdriver to turn the screw. Be aware though, that after all this time, the plastic of the arm will be very brittle, and forcing the screw may shatter the mountings of the bracket.
Barry |
30th Jul 2021, 7:34 am | #4 | |
Also see my screw to the left, this goes through the centre of the tracking weight spring and effectively makes the spring stronger, which therefore makes the arm lighter... just a trial at present but seems to work! |
30th Jul 2021, 7:39 am | #5 | |
I think that's true, but still strange not having any means of refining the tracking weight, I mean Philip's quality control must have been amazing to have every head for this model weigh EXACTLY the same?! My problem is dead old Philips cartridge, so I've added a new cart in the shell, but new cart would like no more that 4g, but Philips arm is giving me 5.8g |
30th Jul 2021, 11:54 am | #6 |
The screw on the left which is attached to the spring is the one I was referring to. That adjusts the weight. Philips made two different styles of cartridge for this deck, the infamous "tilting" one, the other being a larger wedge shape, with a red "flip-under" stereo cartridge. That was heavier than the "tilting" version, and required the weight to be adjusted accordingly, hence the screw and spring arrangement.
Barry |
30th Jul 2021, 12:27 pm | #7 | |
The screw on the left is actually a plain set screw from my parts bin and not an official Philips thing, but good to know that perhaps I'm on the right track. The screw meshes well within the spring and even allows some fine adjustment, the big issues are will it maintain consistently the new lighter tracking weight across the horizontal arc of the tonearm when in use, and will it not foul the housing when that is screwed back over the bubble arm (housing not shown in pic 2 but is in pic 1), I'll trial this over the best few days |
30th Jul 2021, 6:08 pm | #8 |
Re: Adjusting tracking weight on a Philips AG1014 / Disc Jockey
I thought that screw looked a bit odd, it's usually buried deep in the hole, and has no head. No arm that relies on a stretching spring for adjustment will maintain the same weight as the arm rises vertically over the height of a stack of records. It's just something that us fans of autochangers have to accept, but I can't see the problem concerning the horizontal arc of the arm affecting the weight
Barry |
2nd Aug 2021, 7:44 am | #9 |
ok I seem to have a good solution for this
First I'll explain the factory set up. These tonearms have virtually no overhang beyond the tonearm pivot, so they use a spring to pull down what little overhang there is to lighten the tonearm at the cartridge end, pretty crude and unadjustable. Solution #1 - fit a stronger spring. Problem with this is finding such short springs at the exact tension you need Solution #2 - bend up the top tab that the spring is attached to (see photo), to increase the tension. I tried this, at best you get 0.2g reduction at cartridge end, not enough really Solution #3 (the best) - fit a 12mm M4 set screw inside the tension spring from the top. the m4 threads mesh well with the spring's coils and effectively allows you to ramp up the tension incrementally, which allows quite fine adjustment at the cartridge end. When set lock it with a tiny dab of hot glue. I set my tracking weight to lower than the desired figure as I can allways add tiny bits of weight at the cartridge end (bit easier than removing the tonearm back cover, removing the hot glue and adjusting again) The one concern with #3 was will the screw head foul the tonearm back cover, mine didn't but if yours does you could always grind the head down a bit, remember it's not the weight of the screw that makes this work its the fact it locks a few coils of the spring and that action increases the spring's strength Cheers Joe |
2nd Aug 2021, 10:00 am | #10 |
Why not cut the head off the screw, then cut a slot in the top of the rest of the thread to take the screwdriver? (as per the original)
Barry |
2nd Aug 2021, 11:32 pm | #11 | |
Barry |
3rd Aug 2021, 6:48 am | #12 | ||
