16th Sep 2005, 10:37 am | #1 |
Foam tape for loudspeaker mounting.
Has anyone found a good replacement for the 6mm self adhesive foam sealing tape such as found on '60s Philips radios? The draught sealing tape that I have found in local hardware stores is much too dense and will not compress sufficiently. The original sealing tape is a much more 'open' (i.e. less dense) foam, with larger bubbles compared with the stuff that I have found.
Ron |
16th Sep 2005, 4:48 pm | #2 |
Re: Philips Radio Foam Sealing Tape
CPC/Farnell supply two types:
http://cpc.farnell.com/jsp/endecaSea...=LS00624&N=411 and http://cpc.farnell.com/jsp/endecaSea...=LS00625&N=411 Nick. Last edited by Darren-UK; 21st Aug 2007 at 9:50 pm. Reason: Supply info updated. |
