Old 27th Mar 2019, 10:50 am   #41
ajgriff
ajgriff's Avatar
Default Re: Polishing old cloudy transparent plastics
Great job Mr B. As a Gimp user too I particularly like the reproduction scale. I can see how Brasso, with its solvents, will have worked well in this case. Most of the examples I mentioned in an earlier post were in a much worse state and needed a more aggressive approach.
Alan
ajgriff is offline
Old 27th Mar 2019, 12:23 pm   #42
MrBungle
MrBungle's Avatar
Yes this one wasn't too bad. I was using it as a test bed as I have 4 Heathkit GDOs lying around so if I killed one it wouldn't cause too much upset
Next I have a VTVM to do.
MrBungle is offline
Old 27th Mar 2019, 2:48 pm   #43
ColinTheAmpMan1
ColinTheAmpMan1's Avatar
I recently bought a Heathkit AV-3U valve millivoltmeter which had a very cloudy meter-front. I polished it out using Brasso successfully. The one downside was that this revealed a 4cm crack going from the "L" in RMS Volts to almost the "3" on the Volts scale. I thought of trying to get a tiny drop of chloroform into the crack, but I think it is likely that this will make matters worse. It isn't too bad, actually.
This is the meter that hasn't got the proper handle, which is why I am still looking for one.
Colin.
Last edited by ColinTheAmpMan1; 27th Mar 2019 at 2:52 pm. Reason: Grammatical improvement.
ColinTheAmpMan1 is offline
Old 28th Mar 2019, 12:28 am   #44
MrBungle
MrBungle's Avatar
I actually saw a new in box movement go past the other day for one of those which had a nice clean front. I was considering buying it until it hit £26.50!
I finished the restoration of this GDO. It's working nicely even if the dial calibration is, err rubbish. I'm poking it at the digital scope to get the frequency out of it instead. Does the job!
Quick picture:
I shall attack the remaining VTVM in a few days once I've got over the shock of actually completing a restoration
MrBungle is offline
Old 30th Mar 2019, 3:28 pm   #45
BulgingCap
I always start off with 'Jif', or whatever they call it in your part of the world. It is cheap. I have had success on my father's Micra headlights (famous for going yellow) and, using a cheapo car buffing machine, on the very matt and faded orange superstructure of my glass fibre cabin cruiser. I finish off with Autosol or Cerium Oxide (red colour, cheap from China) on meter faces or homemade perspex knobs.
BC
BulgingCap is offline
