10th Apr 2021, 1:34 pm | #1 |
Hmv 1122
Thought I would share these pictures of the HMV1122 set I got hold of, this is the one with the cracked glass scale, in the end I had to get some super glue and carefully stick the pieces together and the selotape. The set did not work when I got it at all and with a bit of tlc it is now back to life. I also found that to work on the underneath the use of a keyboard stand adjusted to suite the chassis was just ideal.
Ken Last edited by Radio Tech; 10th Apr 2021 at 1:36 pm. Reason: third photo loaded by mistake |
10th Apr 2021, 1:46 pm | #2 |
Re: Hmv 1122
I am quite impressed with modification 3rd picture.
John |
10th Apr 2021, 1:50 pm | #3 |
Re: Hmv 1122
Yes sticking a Bush TR82 chassis in there is a bold move.
Cheers Mike T
