4th Apr 2021, 5:15 pm | #21 |
Re: 1966 Phonomaster Diplomat suitcase record player w/BSR UA25 turntable
As far as BSR Autochangers are concerned, the UA25 is very much a budget unit and regarded by most as having a far more "value-engineered" build quality than the earlier BSR UA12, 14, 15 and 16 series. However, they are reliable and certainly worth saving and maybe using with a better amplifier and speaker. The tone arm is pre-wired for a stereo cartridge.
Edward. |
5th Apr 2021, 3:15 pm | #22 | |
I have been looking this over and a lot of other information and frankly I have become overwhelmed! All I have been able to accomplish is the disassembly for the above pictures. I have plugged it in and the turntable turns at all speeds, but no output sounds through the speaker, which at first made me think the amplifier might be the culprit. Even though I haven't touched the unit to continue to try get it to work, I have been thinking about it and processing information(a lot to do for this tired brain! Also the fear of chasing this whole project down a costly rabbit hole!) Somewhere I read something about ceramic cartridges going bad(may have been on of your posts) and have begun to think that the cartridge needs to be tested at minimum and replaced at maximum. So I'm just beginning to try and figure out what needs to be done to test the cartridge and where to get a replacement. Thank you for the above location to check! Now to decipher your statement "a near enough high output" and match a cartridge to the unit! |
5th Apr 2021, 6:12 pm | #23 |
5th Apr 2021, 6:37 pm | #24 |
Before you confirm the condition of the cartridge, is the amplifier working?
You can test this by touching the pick-up input wires to the amplifier and see if you get a loud Buzz throught the speaker. By the way, it's CRYSTAL cartridges that tend to go "bad", not the later Ceramic types.
Edward. |
6th Apr 2021, 12:42 am | #25 | |
6th Apr 2021, 12:46 am | #26 | |
6th Apr 2021, 12:48 am | #27 | |
