Old 9th May 2015, 11:18 am   #1
ukcol
ukcol's Avatar
Default Another POSSIBLE substitute for drive cord
I bought from Boyes yesterday, from the crafts section, some Black Bead Thonging. It is available in 4 yard lengths and is 1mm in diameter. It looks like it may be suitable for use as drive cord but I haven't got an immediate requirement for any and so haven't been able to try it out, hence the "POSSIBLE" in the thread title. At £1.49 I thought it was worth getting some for stock.
ukcol is offline
Old 9th May 2015, 12:24 pm   #2
Refugee
Refugee's Avatar
Default Re: Another POSSIBLE substitute for drive cord
I have used necklace cord with success even on Phillips sets with all the complication. Is that the same stuff?
Refugee is offline
Old 9th May 2015, 1:58 pm   #3
ukcol
ukcol's Avatar
I suspect it is; they call it Bead Thonging but I believe it is for necklace making.
I did BTW, a crude test with a round screw-driver blade and it seems to have plenty a grip.
ukcol is offline
Old 11th May 2015, 5:24 am   #4
Refugee
Refugee's Avatar
It is quite waxy and has good adhesion to steel and can be twiddled to form a point for feeding through Phillips tuner flexy tubes.
Refugee is offline
Old 2nd Dec 2015, 12:17 am   #5
murphy512
murphy512's Avatar
I have used some 1mm Roman blind cord on a Ferguson 208U and it appears to work very well.
It comes in a 20 m length and was only a couple of pounds.
murphy512 is offline
Old 2nd Dec 2015, 2:11 pm   #6
Skywave
On a couple of occasions I've used plastic thread intended for making cableforms. It's reasonably stretchy and does give a reasonable grip on the drum and tuning spindle.
Al.
Skywave is offline
Old 2nd Dec 2015, 3:12 pm   #7
telstar
Hi. Another good substitute for cable drive (used in Philips & Mullard radios) is cord used by the building industry (made by Draper). It is thick enough for the job, and it works very well. My Mullard MAS281 required its cursor drive replacing, and after fiddling about with replacement cable and thinner drive cords (the latter did not work as it was too thin for the cursor plates to grip it).
Mike
telstar is offline
Old 7th Dec 2015, 11:02 pm   #8
FrankB
Cod line aka Cuttyhunk, works fantastic for thicker dial cords.
I still have 2 full reels of it on the Halibut reels my father had.
FrankB is offline
Old 7th Dec 2015, 11:54 pm   #9
TrevorG3VLF
TrevorG3VLF's Avatar
I have some pretty orange cord which I use for guy rope for my mast.
It is 1.6mm diameter and consists of 3 x 3 strands, 0.3mm diameter. I have used a single strand of this for a dial cord.
If you wish to have some, let me know either your address or telephone number and how much you want.
TrevorG3VLF is offline
Old 8th Dec 2015, 6:39 am   #10
joebog1
I have seen a few posts here re: Dial Cord.
If you have trouble getting hold of it, I can do an order from my supplier for you
by "you" a larger order of maybe 5 or 10 rolls is better for me as it costs $16.50 for freight from Sydney to me.
Its very high quality, and I havent had any drama with fitting it.
It fits into the "medium" thickness category. Air mail from Australia to Britain costs a few bucks ( maybe $20)
If you need some I can organise it for you
Joe
joebog1 is offline
Old 8th Dec 2015, 6:50 am   #11
joebog1
I maybe should have added:
I have 3 types of dial cord; two of which are like me old
BUT to give you an idea of size here goes
Thick dial cord = .8mm diameter
Medium is the 100 mtr roll I offered to get if needed it measures .65 mm dia.
Thin = .4mm dia
I measured these cords with my Helios dial guage!!. So the measurements are pretty accurate.
Joe
joebog1 is offline
Old 8th Dec 2015, 10:07 pm   #12
Heatercathodeshort
Heatercathodeshort's Avatar
I have used the strengthening cord from stripped out rubber mains cable and non kink iron flexes. Pull it over a candle before fitting. It works a treat! John.
Heatercathodeshort is offline
Old 16th Feb 2016, 5:53 pm   #13
Andrew B
Andrew B's Avatar
I use thread designed for stitching leather, it does have a preparation (wax?) on it, but it's very strong and grips well.
worried about the electrons entering the circuit and the smoke leaving
Andrew
Andrew B is offline
Old 16th Feb 2016, 10:48 pm   #14
Oldcodger
Andrew- from memory for leather work, it's not beeswax, but one which is water resistant. but if it's the same thickness as used in the shoemaking trade, I'd think it's a bit heavy. I've found that at around 12m , the strip cord in 8w telephone cable works well .
Oldcodger is offline
Old 18th Feb 2016, 12:57 am   #15
marconi_pete
marconi_pete's Avatar
I've used Fishing line for replacing radio dial cords in the past with success. comes in different breaking strengths and thicknesses too. Well worth having some in the toolbox.
Thanks,
Peter
marconi_pete is offline
Old 18th Feb 2016, 9:47 am   #16
mark pirate
mark pirate's Avatar
I have been using cord from a kiddies kite for the last few years, it is the correct diameter, grips well and does not stretch. It also looks identical to the original
I have re-strung quite a few sets with it, and still have loads left. Certainly well worth keeping an eye out for!
Mark
ID:	120248   Click image for larger version
mark pirate is offline
