24th Apr 2017, 11:40 am | #1 |
What is this tool?
Acquired in a recent job lot of spares was this tool, it is branded MHJ and was made in Sweden. It has some small sharp points that point down into the V of the plate on the base. It has Electronics scratched into the handle. Has anyone ever used one or seen one before.
Thanks Chris |
24th Apr 2017, 11:47 am | #2 |
Re: What is this tool?
Seems to have some similarities with a Jakari knife
That's used for stripping cable I still have mine (Jakari) that was issued back in 1978........ Somewhere Cheers Mike T
24th Apr 2017, 11:56 am | #3 |
Hi
Yes it is for stripping the outer jacket from cables. I used one in the 1980's to strip multipair telephone cables. It required careful setting to avoid nicking the insulation on the pairs but was safer for unpractised users than the stanley knife! Ian |
24th Apr 2017, 12:31 pm | #4 |
Thanks that's useful to know, I thought it might be something like that, I will give it a try and see if it is useful.
Does that mean it can cut around the cable and length ways? Chris |
24th Apr 2017, 12:43 pm | #5 |
Hi
Yes Thats the method although I never used it on anything smaller than a 20 pair cable. Ian |
24th Apr 2017, 2:28 pm | #7 |
Up to now my preferred tool was the Cyclops and where that didn't work a Stanley knife was used. When I just tried the tool in post #1 I found that with small flexible cable it rotated with the tool so it looks like it needs a thicker rigid cable to work well.
Chris |
24th Apr 2017, 5:37 pm | #8 |
We have them at work but I never use mine. I prefer the old Stanley knife for stripping armoured cables. As long as you are careful and cut away from you it's fine. Unarmoured cables are a bit trickier. You have to be careful not to nick the insulation on the pairs, which gives problems later on when the damp gets in and corrodes the copper. Always right in the neck of the cable. I use a junior hacksaw to nick the armour strands once stripped and this makes snapping them easier and gives a clean break.
