Old 7th Jul 2020, 2:08 pm   #1
omegaman1969
Default Schaub Lorenz 5001 need help
Afternoon all,
I have a couple of 5001 music centres, 1 works fine, the other one needs some work.
I have gone through the basics, fixed the lack of illumination (blown fuse) checked all the relays and cleaned the connections. Sorted the seized tuning capacitors etc.
I now have the radio working, on AM at least. The tape player doesn't play. When I switch the tape unit on, it lights up and the large wheel on the left (viewed from the front) is spinning happily. I have cleaned all the leaf contacts that I can see. The selector is very stiff to turn compared to my working set.
What would be the best thing to check next ?
Help would be much appreciated.
Thanks
omegaman1969 is offline
Old 7th Jul 2020, 10:44 pm   #2
tri-comp
Default Re: Schaub Lorenz 5001 need help
Have a look at this:
https://www.vintage-radio.net/forum/...d.php?t=106148
You'll even find a link for a download of the full service-manual in post #11.
Be carefull when downloading the manual; select the right download-button or you may have your computer infected with nasties.
The right button is the larger blue squareish button that has a white cloud with a blue arrow pointing in.
Good luck fixing this lot
rgds,
/Torben
tri-comp is offline
Old 10th Jul 2020, 5:10 pm   #3
omegaman1969
Thanks, I have the service manual.....I'll keep checking switches etc .
