Old 11th Jan 2020, 6:07 pm   #1
ennislove
Question Connecting my Cadet TV to my Mac laptop???
I want to transfer visuals to my vintage Cadet TV however I'm not sure what cables I needs as the TV does not have HDMI. So I'd therefore need an adapter.
If anyone know, would be a massive help, thank you!!
The model number of the TV is CM6519A
ID:	196900   Click image for larger version
ennislove is offline
Old 11th Jan 2020, 6:10 pm   #2
Default Re: Connecting my Cadet TV to my Mac laptop???
Hello and welcome to the forums.
Does the TV have any inputs apart from the loop aerial?
What video outputs does the Mac have?
Station X is online now
Old 11th Jan 2020, 7:59 pm   #3
toshiba tony
toshiba tony's Avatar
The Cadet only had RF in, however, it had a mains transformer that provided mains isolation. Finding a suitable place to inject video and audio should be easy.
toshiba tony is offline
Old 11th Jan 2020, 8:19 pm   #4
Nuvistor
Nuvistor's Avatar
Unless you have a compelling reason to use the Cadet it would be simpler and probably not much difference in cost to get a computer monitor. Amazon have them for £60-70, cables and converters could be could be more than half that cost.
If the Mac laptop is less than 10 years old it will probably have a Display Port of some sort, connectors changed with the age of the model.
Frank
Nuvistor is offline
Old 11th Jan 2020, 8:40 pm   #5
paulsherwin
paulsherwin's Avatar
You can buy HDMI-composite video adapters for a.few pounds from eBay sellers, but you will need to squirt the video/audio into a UHF modulator to use the RF input. You can use an old VCR to provide the modulator, but it's a bit bulky.
paulsherwin is online now
Old 11th Jan 2020, 11:24 pm   #6
toshiba tony
Yes, I wondered about the desire to use a tv like that for display purposes.
Old 12th Jan 2020, 2:06 am   #7
19Seventy7
19Seventy7's Avatar
It's possible, I do this myself occasionally.
I use a VGA to Composite converter, my modulator has composite, which converts it to RF. I'd assume the Macbooks have VGA out.
https://www.ebay.co.uk/itm/PC-Laptop...72.m2749.l2649
https://www.amazon.co.uk/dp/B018LKA4...ing=UTF8&psc=1
I'm not associated with either seller, these are just what I use, and could be an option for you.
Hope that helps
'77
19Seventy7 is offline
Old 12th Jan 2020, 2:25 am   #8
arjoll
arjoll's Avatar
No, Macbooks have never had VGA out! It'll be something like Mini Displayport or Thunderbolt.
Easiest option would be an adapter to HDMI, then HDMI to composite, then into a modulator.
arjoll is offline
Old 13th Jan 2020, 8:39 pm   #9
crackle
Wont the picture quality be poor and very low resolution compared to a laptop screen.
Mike
crackle is offline
Old 14th Jan 2020, 12:30 am   #10
arjoll
arjoll's Avatar
Yes, but I assume the OP would probably be doing it for effect, not a high quality image.
They may even be trying to achieve something like this where the producer borrowed an old Pye TV from me; in that case they cheated by superimposing the image in post, but it's possible the OP is wanting to do something live.
arjoll is offline
