31st Mar 2020, 10:53 am | #21 |
Re: Teac AG-H350 No Audio
The power goes from the power transformer to the rectifier and smoothing capacitors and then onto the power amplifier.
In your case, the power amplifier is on a separate board, so its easy to disconnect. As the fuses blew without the power amp connected, it leaves only the bridge rectifier and smoothing capacitors, though not impossible, its unlikely the smoothing caps would have failed which leaves the bridge rectifier. As an aside, I would have reached the same conclusion very quickly had the power supply and amplifier been on the same board. A few posts earlier you stated you didn't find any shorts. if it was me, I'd have measured the resistance of each output transistor C-E if none were short, it would point to the bridge rectifier. |
16th Apr 2020, 4:23 pm | #22 |
Hello, part finally turned up. I got round to fitting it just now and both fuses F701 and F702 blew at the same time on KUP11468-3. I'm really lost now. Hope everyone is keeping well during these times.
Thanks for reading,. Michael. |
16th Apr 2020, 5:45 pm | #23 |
I’ll send you a PM.
16th Apr 2020, 6:03 pm | #24 |
That's the power of this forum. There's a number of seriously experienced repairers around who have built up a formidable amount of knowledge of the usual faults on a wide range of domestic equipment. This makes them fast. Fast was very important in order to be profitable in the repair business.
I come from a background as a designer. Maybe this helps with versatility, being able to analyse things I've never seen before, but it makes me glacially slow, and I'm staggered by how fast the experienced repairers are. David
16th Apr 2020, 7:40 pm | #25 |
