Old 13th Nov 2017, 8:26 am   #1
mickyfinn
Default Wanted 6.3v transformer
Can be 240 or 110v input but 6.3v output at least 5A. Even better would have 110v out too. Please PM if you have anything suitable.
Mick
mickyfinn is offline
Old 14th Nov 2017, 3:12 pm   #2
Diabolical Artificer
Diabolical Artificer's Avatar
Default Re: Wanted 6.3v transformer
Sorry, don't have anything like that Mick. If it were me I'd buy a suitable toroid off ebay, take off the secondary and wind your own. It's easy to do, power up the tfmr with 10 turns on, with, for a heater winding say, a big 50ohm or two 100 ohm in parallel resistors as load and take a voltage reading. Measure length of said 10 turns, do the maths, measure out your wire, with about 1ft extra for every 10ft and an extra 5ft for luck . Do your heater wndg first, and power up and take a reading before trimming and dressing your lead out wires. secure said leadout wires with masking tape or whatever.
Use this table (others available) to get your wire gauge - https://www.engineeringtoolbox.com/w...ges-d_419.html
You transfer your wire to a bobbin, say a scrap of wood a foot long a tad under the core dia wide. Will take an afternoon or so. Finish with Kafton tape. Wire available here - http://www.brocott.co.uk . No relationship with the company just happy customer.
Andy.
Old 14th Nov 2017, 4:16 pm   #3
merlinmaxwell
merlinmaxwell's Avatar
Just get a 6V torroid, it will be near enough.
merlinmaxwell is offline
Old 14th Nov 2017, 4:33 pm   #4
mickyfinn
Thanks very much for replies,its for a Seeburg jukebox amp which normally gets its power from the receiver which contains the 110 and 6.3 suppies.I want to use the amp in a different application without the receiver,the 110v is no problem,the chap that services my amps says the 6.3v needs to be around 50va.
Mick
Old 14th Nov 2017, 5:07 pm   #5
merlinmaxwell
A 100VA toroid will give a wee bit more than 6V loaded to 50VA and run cool as well. Also a dual 55V one would give the 110V series connected. Quite cheap as they are commodity devices now.
Old 14th Nov 2017, 5:42 pm   #6
mickyfinn
Merlyn Maxwell could you possibly take the trouble to give me a link to something suitable?
Mick
Old 14th Nov 2017, 6:30 pm   #7
astral highway
astral highway's Avatar
Mick, forum rules allow EBay to be mentioned, but not links to items on it. But have a look there, plenty of choice.
VA is (without any exception that I've seen) always listed.
The winding job is really easy
Al
astral highway is offline
Old 14th Nov 2017, 7:20 pm   #8
I thought Ebay straight links to a suitable item were OK. (As long as you're not the seller!)
Just don't start any discussion about it.
Herald1360 is offline
Old 14th Nov 2017, 7:22 pm   #9
mickyfinn
Whoops forgot sorry
Mick
Old 15th Nov 2017, 5:06 pm   #10
daviddeakin
daviddeakin's Avatar
If you buy a 230V:6V transformer and run it at 240V, which is what we actually get out of the wall in the UK, you will get 6.3V. Neat, huh!
daviddeakin is offline
