Old 26th Jul 2009, 9:58 pm   #1
TrevorM6TSE
TrevorM6TSE's Avatar
Default Local help for a VHF80c
Hi All,
OK, so I've hit a block on this one! I've been restoring a Bush VHF80c for some time now and I've got it electrically nearly 100% apart from one VERY annoying thing...
When it's cold and you turn it on it works fine on LW and MW, but on VHF you get background white noise and a crackle but no stations. As it warms up fully the stations come in, but the "crackle" keeps taking them away and leaves you with just white noise. After about 30 mins it will settle down. If you leave it off for a few weeks it takes even longer to fully work.
I've changed all suspect caps, cleaned valve bases, changed the UCC85, moved the two UF89's round and had it on the bench and prodded around to try and produce the fault to no avail. I've cleaned the wavechange switch as well. I've also been in the FM front end and resoldered and checked in there.
So, I'm at a loss! Could I have a fault in a IF can or similar? Dodgy valve?
I'm looking ideally for another member in the Derbyshire/Notts area to have a look for me and see what I've missed.
Any help greatfully received.
Trev
I'd just like to say "Good luck, we're all counting on you"
TrevorM6TSE is offline
Old 27th Jul 2009, 12:09 pm   #2
'LIVEWIRE?'
'LIVEWIRE?''s Avatar
Default Re: Local help for a VHF80c
I have a similar problem with a VHF90C, which is an FM Only Radio. This had been dropped, but I can see no evidence of any damaged or broken parts, dislodged cores, etc.
Like you, I have replaced capacitors & resistors, changed the UCC85, etc., to no avail. What are we missing?
'LIVEWIRE?' is offline
Old 27th Jul 2009, 12:33 pm   #3
Leon Crampin
On the Bush sets with Plessey slider wavechange switches (including VHF61 and less often, the '64), crackling is almost always tracking in the switch sections from HT (or thereabouts) to some adjacent contact.
These switches have very close spacing between contacts - they are interleaved front and rear - and the paxolin grade is rather poor. Sometimes there is a workaround; one of my VHF61s had a bad crackle cused by HT tracking to the switch in the AF feedback network. Luckily, there were enough unused spare contacts for a (rather devious) fix.
Obviously none of this can apply to the '90C - but check all Hunts have been evicted. I don't have the circuit of the '90C to hand, but I did once have an inexplicable crackle on a Murphy U502 which was caused by a CZ1 thermistor with a crack in it. Freezer is often the way to find this type of problem.
Leon.
Leon Crampin is offline
Old 27th Jul 2009, 8:00 pm   #4
TrevorM6TSE
I did think about the wavechange, but in the VHF80 and 81 it's quite a big three button push switch with all the elements open and visible. I've cleaned it using serisol switch cleaner, but it still does it
I've also prodded the wave change a few times, but it makes no noticeable change.
Anything else I should check? It's driving me nuts!
Old 27th Jul 2009, 8:31 pm   #5
Steve_P
Steve_P's Avatar
Get your Signal Generator and couple it loosely to the IF out of the VHF box. When there's no VHF, do you still get the 10.7 Mhz?
Cheers,
Steve P.
Steve_P is offline
Old 28th Jul 2009, 5:41 pm   #6
TrevorM6TSE
Cheers,
Steve P.
Hi Steve,
Unfortunately I've not really got the gear to do this I'm Afraid Ideally I'm looking for a local member to take a look for me.
cheers
Old 28th Jul 2009, 11:31 pm   #7
PJL
I looked at the repair notes on a VHF81 I did a while back and the reservoir capacitor in the ratio detector was a problem. It's a small electrolytic.
I have also had IF capacitor problems on a couple of Bush radios but as I recall it was the 465KHz not 10.7MHz IF.
I guess you have already tried wriggling valves in their sockets and the wavechange buttons to see if this has any effect?
You kind of already have a signal generator as you are getting white noise. I don't have a circuit but perhaps someone can suggest a few places where a small capactior could be put between grid and chassis/cathode to work back through each stage to see where the noise is coming from.
PJL is offline
Old 29th Jul 2009, 10:52 am   #8
Steve_P
Steve_P's Avatar
Take DC measurements on the valves too. Might show something up.
Before and After the fault occurs and corrects itself. If applying a meter probe clears the the problem then that is a big clue.
Might be worth using freezer spray - carefully....
Cheers,
Steve P.
Steve_P is offline
Old 1st Aug 2009, 5:04 pm   #9
TrevorM6TSE
Hi All,
Well I've spent a number of hours on this set now and it's still doing it. I've changed a number of resistors, checked voltages etc and it all seems well. It'll play fine for a few minutes then crackle and just white noise. Moving the wavechanger does nothing, tapping it does nothing. I've been in the FM front end and re soldered, prodded, etc and still the same!
I'm at a loss with it now, in fact I've had to wlak away from it as I was beginning to lose my temper!
Anyone local fancy having a look? If not, it's going in the loft never to be seen again!
Old 1st Aug 2009, 5:26 pm   #10
Top Cap
Top Cap's Avatar
Have you another VHF radio to hand that you can use as a test receiver? You could try tuning it to around 88MHz then place it close to the Bush. Tune the Bush to somewhere around 98MHz and you should hear a strong carrier signal appear on the other test receiver which is the local oscillator of the Bush. Note the tuning position on the Bush where you hear this carrier and set the Bush to receive a local station. When the station fades due to the fault, check to see if you can still get the test receiver to pick up the Bush local oscillator as before. If you cannot, then the local oscillator is shutting down for some reason, at least it may help narrow the fault for you.
Les
Whether the Top Cap is Grid or Anode - touching it will give you a buzz either way!
Top Cap is offline
Old 1st Aug 2009, 5:28 pm   #11
matthewhouse
matthewhouse's Avatar
I have a Marconi set doing this at the moment, one minute it works, the next just white noise. The fault on my set is a faulty ceramic trimmer in the FM box. It looked ok but as soon as I prodded it, it fell apart.
matthewhouse is offline
Old 1st Aug 2009, 5:52 pm   #12
Phil G4SPZ
Phil G4SPZ's Avatar
The tip involving a second set to generate a beat note is a good one, as is the use of freezer aerosol spray. Alternating with a hairdryer, this can be a quick way of localising faults with a thermal cause.
It sounds almost as if the local oscillator is suddenly going way off tune. I had a similar fault in the VFO of a Heathkit ham-bands transceiver once, where the frequency would suddenly jump a few kHz, and it turned out (after exhaustive replacement of caps) to be corrosion on one of the soldered ends of the oscillator coil.
Phil
Phil G4SPZ is offline
