Old 26th Jan 2008, 11:30 am   #1
Hunts smoothing bomb
Hunts smoothing bomb's Avatar
Default Replacing PCF200's
Morning all,
Just after a bit of advice really, I want to replace the PCF200's in my Philips K70 and would like to know if any setting up of any kind should be done after replacement or not.
Lee
Lee
Hunts smoothing bomb is offline
Old 26th Jan 2008, 1:24 pm   #2
Mikey405
Mikey405's Avatar
Default Re: Replacing PCF200's
Hi Lee.
Personally, I would just replace them and see what the picture is like. If the grey scale is slightly off then you could make a minor adjustment but otherwise just go for it.
From Mike.
G7TRF
Mikey405 is offline
Old 26th Jan 2008, 1:41 pm   #3
Focus Diode
Focus Diode's Avatar
I second Mikey's advice. The G6 also uses PCF200s of course. I found on swapping them around the grey scale was well off, but putting them back in the original order restored good results, that is when first fitted and the grey scale set up.
If the grey scale and performance is ok do your PCF200s really need replacing?
Brian
Focus Diode is offline
Old 26th Jan 2008, 2:38 pm   #4
Steve_P
Steve_P's Avatar
I'm with Mikey here. Just change them (if you feel you need to!) and switch on.
Cheers,
Steve P
Steve_P is offline
Old 26th Jan 2008, 4:38 pm   #5
Mike Phelan
Mike Phelan's Avatar
I must admit that when G6s and K70s were a bit newer, PCF200s hardly ever needed replacing, unlike their compatriots, the PCL84 (although in fairness, that wasn't always the valve's fault).
Mike.
Mike Phelan is offline
