4th Mar 2018, 7:33 pm | #1 |
"SW-05" diodes.
I'm reworking a Trio 9R-59 communications receiver and it includes a number of strange diodes/rectifiers in the signal and AGC paths.
They're marked "SW-05", black-encapsulated lumps about the same diameter as a Polo-mint. Strangely, these often form half of a voltage-doubler network with a 1N-60 diode as the other half. Does anyone know what the charateristics of these boiled-sweet-sized diodes are?? |
4th Mar 2018, 9:10 pm | #2 |
Re: "SW-05" diodes.
Radio Museum has a little info, silicon power supply diode.
https://www.radiomuseum.org/tubes/tube_sw-05.html
Frank |
4th Mar 2018, 9:14 pm | #3 |
Re: "SW-05" diodes.
Possibly similar to 1N4007
4th Mar 2018, 9:17 pm | #4 |
Re: "SW-05" diodes.
Just have a look at the circuit diagram and pick something to serve in the actual application.
4th Mar 2018, 9:19 pm | #5 |
Re: "SW-05" diodes.
I also thought these were power rectifiers. I've no idea what they're doing in an RF circuit.
4th Mar 2018, 9:37 pm | #6 |
Re: "SW-05" diodes.
4th Mar 2018, 9:58 pm | #7 |
Re: "SW-05" diodes.
Just had a look at the parts list in the service manual.
The diodes in the PSU are specified as S-05-08, the others as S-1.5-02. This differs from the block diagram and circuit diagram in the same publication. I have no idea what's actually fitted or whether the specs differ.
4th Mar 2018, 10:10 pm | #8 |
Re: "SW-05" diodes.
Some power diodes such as 1N400x also work as varicap diodes.
4th Mar 2018, 11:34 pm | #9 | |
Re: "SW-05" diodes.
I wouldn't expect to see one used as a diode at RF or IF frequencies. David
4th Mar 2018, 11:34 pm | #10 |
Re: "SW-05" diodes.
Diode D5 is part of the noise limiter, and is a silicon type chosen probably for the slightly higher voltage barrier.
If it works, leave it alone. If you must test it. Measure it in circuit for resistance, with rx power OFF. If the ratio of resistance from one polarity to the other with your meter leads is 10 to 1 or higher, then it is probably OK. If not, or suspect, lift one leg and repeat, paying attention to leakage, ie back resistance. Replace with 1N4004 or similar silicon diode, even a 1N918 or 1N4148 should be OK. In this circuit, these diodes should be virtually indestructible, and last forever. |
5th Mar 2018, 11:51 am | #11 |
Re: "SW-05" diodes.
The NTE equivalent of the SW-05 is listed as NTE5800 (3A 50V), and I suspect if it has 08 tagged to the part number, it would be the NTE5808 (3A 800v)
That should equate to 1N5408. Datasheet here: http://www.farnell.com/datasheets/1483202.pdf |
5th Mar 2018, 12:38 pm | #12 |
Re: "SW-05" diodes.
Thanks for the info. I'm not thinking these diodes are faulty, just that I'm trying to track down a low-gain problem in this particular radio and was somewhat surprised to see such diodes used in the detector and AGC circuitry!
It's deeply odd to me that the voltage-doubler for the AGC bias has one of these 'power' diodes and a 1N60 point-contact diode. Why one of each? I could understand two 1N60 being used but there must be a reason why Trio did what they did. |
5th Mar 2018, 5:49 pm | #13 |
Re: "SW-05" diodes.
The 1N60 is a germanium detector diode which will have a low voltage drop. The SW-05 are silicon diodes which have a larger voltage drop and may be used for very low voltage Zener diodes.
I have seen a handful of the SW-05 diodes in an electric fencer used for their high voltage ability. |
5th Mar 2018, 6:18 pm | #14 |
Re: "SW-05" diodes.
The manual states that a C bias , presume they mean -ve, is fed to the AVC via the aux socket, it can be used to remotely control the radio, presume mute, when transmitting.
Could this silicon diode have to have been used with it having higher reverse breakdown voltage than the 1N60?
Frank |
5th Mar 2018, 8:26 pm | #15 |
Re: "SW-05" diodes.
That's something I hadn't thought about!
