2nd Oct 2018, 7:42 pm | #1 |
Defiant MSH 248 capacitor question
Hello,
I have recently purchased a Defiant MSH 248 however I cannot find any service info. The multi section capacitor is 16 and 24uf however I wondered if my assumption is correct that it has a common negative to chassis? Thank you |
2nd Oct 2018, 8:16 pm | #2 |
Re: Defiant MSH 248 capacitor question
It's possible that this Chassis is very similar to the Ultra U502
Might be easier to find a circuit for that one. Cheers Mike t
2nd Oct 2018, 9:01 pm | #3 | |
So yep yep! You're not asking but I hope you can preserve the original, it'll likely reform with a bit of tlc.
Al |
2nd Oct 2018, 10:15 pm | #4 |
Sometimes you will find that some multi section capacitors do not have a negative terminal. In these cases the metal body of the capacitor can itself serves as the negative and the metal clip holding it to the chassis completes the negative connection to chassis.
Thanks, Peter
BVWS and BVWTM member Last edited by marconi_pete; 2nd Oct 2018 at 10:21 pm. |
2nd Oct 2018, 11:42 pm | #5 |
Thanks for the response!
however that is what I meant in my original post however I was not sure if the cap had a common negative or positive to chassis Thank you |
3rd Oct 2018, 8:43 am | #6 |
In 99% of valve radios, etc., the common return point of Reservoir, Smoothing, and Cathode bypass Electrolytic Capacitors is always negative, and the Negative line is almost always the (metal) chassis. Can-type capacitors fitted to sets with printed circuit boards often have tags on their cans which are soldered to the negative track on the PCB
