Reply
Old 18th Jun 2021, 9:46 pm   #21
Sideband
Sideband's Avatar
Default Re: Gec bc402
Mods, can this thread be moved to the correct section please?
On Spike Milligan's headstone......I told you I was ill...
Sideband is offline   Reply With Quote
Old 19th Jun 2021, 7:20 am   #22
Station X
Station X's Avatar
Default Re: GEC BC402 receiver.
If you think a post is in the wrong section please use the red triangle button to report it. It'll get quicker attention that way.
Thread moved to VRD as it's become a repair thread.
"Where can I get.....?" type threads are OK in SP&SIW. After all many threads in that section get replies like "Available from supplier X".
Back on topic please.
Graham. Forum Moderator
Keep the soldering iron hot.
Station X is online now   Reply With Quote
Old 19th Jun 2021, 10:56 am   #23
Dorian27
OK I have taken readings from pin 3 on 3 different meters and what I get with all 3 is the same when first radio is switched on I get 119v dc as the valve warms it goes down to. Point 785v dc. Tried a valve new same reading. Can't tell you any more. Hope this helps
Dorian27 is offline   Reply With Quote
Old 19th Jun 2021, 11:16 am   #24
Station X
Station X's Avatar
Are you saying that the reading starts at 119VDC then drops to 0.785VDC?
Old 19th Jun 2021, 11:30 am   #25
Station X
Station X's Avatar
Try disconnecting one end of R35 (500R) which will leave just the reservoir section of the smoothing caps connected. What's the reading like then?
Old 19th Jun 2021, 11:50 am   #26
Dorian27
I have used 3 diffrent meters and the readings i got on pin 3 is on radio switch on i get 119v dc as the valve warms it goes down to point 785 i then replaced the valve with good working one and same reading hope this helps.
Old 19th Jun 2021, 11:53 am   #27
Dorian27
Sorry I seemed to have posted the same reply twice I will take new reading later thank you very much for much needed help.
Old 19th Jun 2021, 12:24 pm   #28
Dorian27
Well the reading with R35 disconnected is 140v dc and rising as valve warms.
Old 19th Jun 2021, 12:32 pm   #29
Dorian27
I believe according to the service sheet it should be around 175v dc I left it on a while without resistor connected it is now 180v so I've turned it off.
Old 19th Jun 2021, 12:34 pm   #30
Station X
Station X's Avatar
If the rectifier is working correctly and C58 is good the reading should rise to 240VDC or more.
What AC voltage do you see on the rectifier's heater (between pins 4 and 5)?
Old 19th Jun 2021, 12:37 pm   #31
Station X
Station X's Avatar
I don't know where you're getting your figures from, but the two service sheets I've looked at show the pin 3 reading as being 235-238VDC.
Old 19th Jun 2021, 12:41 pm   #32
ms660
ms660's Avatar
Under normal circumstances with R35 disconnected that voltage should rise to the peak value of your mains supply voltage, the peak value of the mains supply voltage is easy to calculate, it's the mains voltage (RMS) multiplied by 1.414, for instance if your mains voltage was 240 volts AC then the peak voltage would be 240*1.414 which would be 339 volts peak AC, the voltage across the reservoir capacitor (C58) would rise to that voltage but that voltage would be DC.
That's one of those things that should be learned early on and never forgotten along with Ohms Law and the fact that all circuits are potential dividers.
Lawrence.
ms660 is online now   Reply With Quote
Old 19th Jun 2021, 2:23 pm   #33
Dorian27
Yes you are correct on pin voltage it is 235 to 238 dc. I don't now where I got 175 from. I went up to 180dc when I turned off as I thout it was 175 and did not want to do any more damage. What do I do now do I let it on to rise or not. Does this mean by disconnecting the resistor that the resistor is faulty or something else.
Old 19th Jun 2021, 2:40 pm   #34
Station X
Station X's Avatar
See how high the voltage rises, but make sure the capacitor doesn't get hot. Turn off the set and disconnect the mains periodically then feel how hot the cap is. Remember that it will retain a charge for some time.
This test is to show whether the rectifier and reservoir cap are OK.
The resistor doesn't come into it and is easily checked with a meter on ohms range.
Old 19th Jun 2021, 3:00 pm   #35
Sideband
Sideband's Avatar
Could you please say which service sheet you are working from? Nowhere does it say that the voltage on pin 3 of the rectifier is 175V.
Old 19th Jun 2021, 4:05 pm   #36
HamishBoxer
HamishBoxer's Avatar
Could even be the smoothing caps pulling the voltage down?
G8JET BVWS Member and V.M.A.R.S
HamishBoxer is offline   Reply With Quote
Old 19th Jun 2021, 4:55 pm   #37
Station X
Station X's Avatar
Could be, but we haven't got as far as testing the rectifier and reservoir capacitor yet. We're waiting for the OP to report test results.
Reply
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Copyright ©2002 - 2021, Paul Stenning.
