Reply
Old 14th Jun 2021, 10:04 am   #1
vinrads
Default Majestic 90B. Bringing a Dinosaur back to life.
This is a Majestic 90b I purchased from Bill as an unfinished project , all the hard work had been done as was looking great , I just had the electronics to sort out , all coils and chokes/transformers checked out OK , two of the smoothing capacitors read low so I decided to replace all four in the massive block ,I had some paper ones rated at 600 volts just managed to squeeze them in, there are only five fixed resistors in the eight valve/tube set I replaced two which had gone high, also replaced the capacitors in five small steel cans ,the speaker was totally stripped and re painted being very careful with Cadmium coating a replacement energising coil was fitted supplied by Bill ,the connecting wire was perishing so replaced it with a piece which I had saved (it will come in handy one day) and so it did a perfect replica , note the massive tuning capacitor cover it housed a five gang capacitor, The set works very well at the HF end but a bit flat at the LF end , will investigate later ,that's it for now I see the paint stripper has just arrived for the cabinet it is a border line case but I think I need to strip it . Mick.
ID:	235872   Click image for larger version
ID:	235873   Click image for larger version
ID:	235874   Click image for larger version
ID:	235875   Click image for larger version
vinrads is offline   Reply With Quote
Old 17th Jun 2021, 4:23 pm   #2
crackle
crackle's Avatar
Default Re: Majestic 90B. Bringing a Dinosaur back to life.
Did you mean paper?
Personally I would not have used paper capacitors, we usually cut those out and chuck them. I would have used 2uF or 4uf 630V Polypropylene types.
Mike
BVWS Member, 2E1MJE
The KB Museum
My collection in the Radio Museum
crackle is offline   Reply With Quote
Old 17th Jun 2021, 9:37 pm   #3
vinrads
Thanks Mike ,the capacitors are vintage ones ex equipment all tested good also given a good soak test at near max voltage ,before fitting ,also I fitted an HT fuse 200ma as the set takes 120 ma the set is in use every day no problem so far , Mick.
Reply
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Copyright ©2002 - 2021, Paul Stenning.
