23rd Apr 2021, 5:04 pm | #1 |
Leak Delta FM.
Hi I have a leak delta I have not taken it apart it yet, I wonder if anyone knows what bulbs I need for it. It has a problem with 2 of the buttons they push in but don't lock in place, can these switches be repaired
Mark |
23rd Apr 2021, 7:44 pm | #2 |
Re: Leak delta fm
There were a few Delta FMs, a picture would help.
24th Apr 2021, 9:51 am | #3 |
Re: Leak Delta FM.
Sorry I didn't know there was more than one type
24th Apr 2021, 11:31 am | #4 |
Re: Leak Delta FM.
Isn't this a cosmetically repackaged Leak "Stereofetic" FM tuner? (Leak also made a similarly styled Delta AM/FM tuner)
24th Apr 2021, 6:14 pm | #5 | |
Re: Leak Delta FM.
Yes, it is!
Jim G4MEZ |
25th Apr 2021, 8:08 am | #6 |
Re: Leak Delta FM.
Hi Mark, I would try a squirt of Servisol switch cleaner onto the switch bank latching mechanism in case it is sticking a little. DO NOT be tempted to use WD40 or such like though. The bulbs I believe are LES type and are available on ebay for example, but you would need to check the voltage of the bulb in the tuner.... I think two are 6.5v 1w, and the other is 6v 0.36w LES 5mm.
Andrew Last edited by PYE 405; 25th Apr 2021 at 8:16 am. Reason: Correction of bulb voltage. |
25th Apr 2021, 7:49 pm | #7 |
Re: Leak Delta FM.
Thanks Andrew the bulbs look all the same. I will have to try take it apart so I can get to them and have a look. I brought it from the bring and buy sale at harpenden sitting in cupboard for a long time think it was £20/25 at the time
26th Apr 2021, 4:25 pm | #8 |
Re: Leak Delta FM.
Would they be the lilliput bulbs
