31st Dec 2015, 11:12 am | #1 |
Resistor just out of tolerance
I have a SG (screen grid?) stopper resistor that measures 43.1ohm. The trader sheet specifies 39ohm and it has a silver band (10%?). I calculate that this resistor is 0.2 ohms too high. Not much but it is over. Would this be considered ok to use in general or is each case specific and if it is specific am I ok with this one? thanks |
31st Dec 2015, 11:13 am | #2 |
Re: Resistor just out of tolerance
It will be fine.
31st Dec 2015, 11:19 am | #3 |
What did you measure it with?
Did you take account of lead resistance? Your measurement errors are likely to exceed the tolerance error of the component. As Graham says, it will be fine.
Brian |
31st Dec 2015, 11:21 am | #4 |
Agree that it will be fine. And it might be just within tolerance anyway, the small difference that you have observed is well within the expected instrument error, unless you are using something of unlikely accuracy.
0.2 of an ohm could even be variations in contact resistance depending on how firmly the test leads were connected to the component under test. |
31st Dec 2015, 11:47 am | #5 |
Stopper resistor values are rarely critical. You could probably use a 33 or 47 without any problems.
31st Dec 2015, 12:12 pm | #6 |
Resistor values are rarely critical in valve domestic radios. I only change them if they are massively out or if a related fault is present.
31st Dec 2015, 5:57 pm | #7 |
Expect 10% resistors to be near the edges of the tolerance band. Those closer to the middle used to get flogged as 5% parts. So a plot of population versus resistance would look "M"-shaped with two peaks and a dip in the middle.
