Old 24th Aug 2017, 3:39 am   #1
Johnbarn
Default Two questions on Hackers
I have a Mayflower 2 on which I have changed the two Hunts 0.5 uF capacitors C31,32.The set is now working very well with lovely tone. Should I change any other capacitors "just for the sake of it" or leave well enough alone? There are two other Hunts capacitors of similar construction but different value.
Secondly on my Sovereign 2 I recently replaced both PP9 batteries because they were causing drop off in performance. New batteries cured this but I was surprised to find that while one of the old batteries was reading 5.5 v on my Avo8 the other was still reading 8.5 v. How can this be when both are in series?
Johnbarn is offline
Old 24th Aug 2017, 7:45 am   #2
Nuvistor
Nuvistor's Avatar
Default Re: Two questions on Hackers
The PP9's, if they are the same make they are probably from a different batch, I have had similar occurrences with C type cells in radios, one cell down much further than the others.
The two Hunts capacitors, if they are the easy to change I would normally replace them, which ones are they?
Frank
Nuvistor is offline
Old 24th Aug 2017, 8:09 am   #3
stevehertz
stevehertz's Avatar
Not sure why you seem to suggest that their voltages should have been equally maintained better as they were connected in series? I'm not convinced that it makes much difference either way (it's down to the 'quality' of the individual battery isn't it?) but hypothetically speaking surely if they were connected in parallel it would help the voltages remain similar better?
stevehertz is offline
Old 24th Aug 2017, 8:25 am   #4
'LIVEWIRE?'
'LIVEWIRE?''s Avatar
The difference battery voltage is most likely due to differing internal resistances of the two batteries. A PP9 (or any other 9v battery) is made up of 6 nominally 1.5v cells. If one or more of these cells is below standard it will have a higher internal resistance to the others
'LIVEWIRE?' is offline
Old 25th Aug 2017, 11:23 pm   #5
Johnbarn
Thank you for the replies. Both PP9s were Ever Ready Silver, same date and from same batch but I suppose the internal resistance is the key and could be different. Frank, the two Mayflower caps which I might consider changing are both yellow Hunts type - C21 and C42, both 0.1uf, but the service manual doesn't give any indication of them causing problems unlike the ones I have replaced, C31 C32 grid couplers which are known to cause distortion. Tempted to leave well enough alone in the meantime. John n
Johnbarn is offline
