Old 3rd May 2020, 7:51 pm   #41
Paulus.d
Default Re: Lockdown project - Sony TC-200
Right side of R5 is 76v.... left side is 29v
During these measurements it's entered fault condition...the volume fades to nothing .. the voltages haven't changed..
Paul
Paulus.d is offline
Old 3rd May 2020, 8:35 pm   #42
ms660
ms660's Avatar
Next, in playback with the fault condition present check the voltages on V101 and X101...
V101 anode (pin 6) screen grid (pin 8) control grid with volume control turned up (pin 9) and cathode (pin 3)
X101 collector (junction of R105 & C104) base (junction of R104 & R103) and the emitter (junction of R107 & the +ve of C103)
Also determine whether the pre-amp transistor (X101) circuit is the early type (germanium transistor) or the later type (silicon transistor) as the expected voltages are different.
Can we assume that the Rec/Pback switch contacts are clean and making contact and that the tape path's ok?
When measuring the base and emitter voltages you need to know to at least one place after the decimal point on the meter, eg: if say on a higher range the meter says 7 volts but on a lower range it says 7.12 volts it's the lower range meter reading that's of interest.
Lawrence.
ms660 is offline
Old 3rd May 2020, 8:53 pm   #43
DMcMahon
DMcMahon's Avatar
Originally Posted by Paulus.d View Post
Also ..even in low volume state...the volume control is still active ...
Would make sense.
DMcMahon is offline
Old 3rd May 2020, 8:56 pm   #44
DMcMahon
DMcMahon's Avatar
Paul
So very close to schematic (Playback) values.
DMcMahon is offline
Old 3rd May 2020, 9:01 pm   #45
DMcMahon
DMcMahon's Avatar
okay here's what I measured...
Pin 7 ....154v
Pin6 ....stablised at 116v
Pin 5 ..... 0 but hums when touched by the probe
Pin 1 ....7.2v
point 3 ....9.7v
point 4 ...... 77v
Paul
Point 3 is the left side of R5 so why is the reading substantially different from Post 42 reading of R5 left side ?
DMcMahon is offline
Old 3rd May 2020, 9:12 pm   #46
Paulus.d
Okay...
Pin 6.... 19.2v
Pin 8..... 0.82v
Pin 9..... 0... and humming when touched
Pin 3 .....0.26v
Record switches and heads are clean
Don't know how to find transistor type... Channel 2's one is a different number and design , OC140
Paulus.d is offline
Old 3rd May 2020, 9:14 pm   #47
DMcMahon
DMcMahon's Avatar
How is the quiet output being determined, i.e. internal speakers (with Line output set to Speaker), line output from Jack socket to Hi-Fi/High impedance headphones (output set to Line), Line output from auxiliary DIN to Hi-Fi or external speaker (output set to speaker) connected to Jack socket.
DMcMahon is offline
Old 3rd May 2020, 9:17 pm   #48
Paulus.d
Pin 7 ....154v
Pin 1 ....7.2v
point 3 ....9.7v
point 4 ...... 77v
Paul
when I measured Point 3 I must have got confused and measured the wrong side of R105...
Paul
Paulus.d is offline
Old 3rd May 2020, 9:26 pm   #49
DMcMahon
DMcMahon's Avatar
Okay...
Pin 6.... 19.2v
Pin 8..... 0.82v
Pin 3 .....0.26v
Screen grid pin 8 is particularly low, try and check out R113/C107.
DMcMahon is offline
Old 3rd May 2020, 9:40 pm   #50
Paulus.d
Screen is at .82 from switch on passed fault condition....reading remains the same...
also update read Pin 9 while varing the volume level ..ranges from 0 to 1.1 during fault condition..
Paulus.d is offline
Old 3rd May 2020, 9:47 pm   #51
Paulus.d
R113 and C107 are linked to Pin 1 of V101. voltage reading starts at 36v then stablises to 18v ... fault condition kicks in ..reading does not change
Paul
Paulus.d is offline
Old 3rd May 2020, 10:09 pm   #52
DMcMahon
DMcMahon's Avatar
Hi Paul,
Are you sure that is V101, my reading of the schematic shows junction of R113 and C107 connected to pin 8 of V101 and you measured 0.82V there before ?
DMcMahon is offline
Old 3rd May 2020, 10:20 pm   #53
DMcMahon
DMcMahon's Avatar
I can see where I am going wrong, pin 8 is the suppressor grid, the screen grid is pin 1, but pin 1 is not shown on the schematic and it looked like the screen grid was pin 8 on the schematic.
DMcMahon is offline
Old 3rd May 2020, 10:24 pm   #54
Paulus.d
Okay ....
Have noticed that the amp produces hum when Pin 9 is probed..... so the issue is before this point ... the music fades away but the amp at Pin 9 is still amplifing...
A big thank you to you all for helping me with this ...I have no idea how todo this on my own and actually it's very interesting work ...
Regards Paul
Paulus.d is offline
Old 4th May 2020, 11:08 am   #55
ms660
ms660's Avatar
Pin 8 instead of pin 1 was my error, my apologies, I was going by the schematic without checking the PCB layout.
I would check the transistor voltages next and also find out what's printed on the case of the transistor in terms of ID, either that or ID the value of R107, that should tell us whether the transistor in the preamp is germanium or silicon and therefore which voltages on the schematic to compare with the voltages measured.
It's funny how things stick in the mind, I remember that head type number PP30-4202 from when I used to service them back in the 1970's.
Lawrence.
ms660 is offline
Old 4th May 2020, 12:24 pm   #56
DMcMahon
DMcMahon's Avatar
Poor schematic not identifying pin 1 (screen grid) and showing pin 8 correctly next to the Suppressor grid but also right next to the Screen grid, it fooled me.
DMcMahon is offline
Old 4th May 2020, 12:27 pm   #57
DMcMahon
DMcMahon's Avatar
Okay...
Pin 6.... 19.2v
Pin 8..... 0.82v
Pin 3 .....0.26v
The OC140 does not appear to be an original listed transistor, does the soldering look like it may have been disturbed/replaced ?
Is channel 2 the problem channel with now signal ?
DMcMahon is offline
Old 4th May 2020, 2:42 pm   #58
DMcMahon
DMcMahon's Avatar
Okay...
Pin 6.... 19.2v
Pin 8..... 0.82v
Pin 3 .....0.26v
Typo error in last line above, should have read "Is channel 2 the problem channel with low signal ?"
DMcMahon is offline
Old 4th May 2020, 2:49 pm   #59
ms660
ms660's Avatar
When I worked for Sony we had reams of manual amendments and revisions for tape recorders and other stuff, here's a better set of schematics showing the valve pinouts and the transistor pre-amp differences:
http://sportsbil.com/sony/TC/TC-200.pdf
Lawrence.
ms660 is offline
Old 4th May 2020, 2:59 pm   #60
DMcMahon
DMcMahon's Avatar
Certainly a lot better, no ambiguity now with pins 1/8
Also see it identifies the output Pentode as 30A5 which I had seen on the artwork drawing, but IT was not shown on the schematics I was looking at and parts list called it 30M-P23.
DMcMahon is offline
