Old 26th May 2020, 4:11 pm   #1
Dorian27
Default Akai X200
Can any one tell me whch side of theis leaver in pictures should the tape run if it on the insise the rape slows or stoos if on outside the tape runs ok can any ckeare this for me please.
ID:	206831   Click image for larger version
Dorian27 is offline
Old 26th May 2020, 7:02 pm   #2
DMcMahon
DMcMahon's Avatar
Default Re: Akai X200
Hello Dorian,
I was going to say that this is the Automatic Stop Lever so outside as per the photos is correct. However I am now confused because if it was the Automatic Stop Lever than it looks far too close to the heads and is in the incorrect orientation ?
Could you please do another photo but showing a larger surrounding area.
DMcMahon is offline
Old 26th May 2020, 7:35 pm   #3
Tape lifter for FF/Rew? If it is then tape on the outside.
Old 26th May 2020, 10:20 pm   #4
Dorian27
Ok i will get a larger area photo tomorrow thanks David and Lawrance
Dorian27 is offline
Old 26th May 2020, 11:29 pm   #5
DMcMahon
DMcMahon's Avatar
Concur with Lawrence, it is definitely the tape lifter arm, so tape on the outside as per the photos is correct, no need now for any more photos for it.
DMcMahon is offline
Old 27th May 2020, 8:52 am   #6
Dorian27
Ok thank you all
Dorian27 is offline
