Old 23rd Oct 2018, 1:19 am   #1
Karen O
Default Ostar Ganz valves
I think I have that spelled correctly.
Does anyone remember these?
I'm told they had 240V heaters.
Karen O is offline
Old 23rd Oct 2018, 1:33 am   #2
Paul_RK
Paul_RK's Avatar
Default Re: Aster Ganz valves
I've never knowingly met one, but a search for Ostar Ganz here and elsewhere brings up abundant info.
Paul
Paul_RK is offline
Old 23rd Oct 2018, 7:31 am   #3
Karen O
Ah... 'Ostar Ganz'
It does help to get the spelling right
Thanks, Paul.
Karen O is offline
Old 23rd Oct 2018, 8:49 am   #4
Radio Wrangler
Radio Wrangler's Avatar
I would expect the very thin filaments needed would make them rather short lived, and hum coupling would be an issue.
Not surprised they're rare! (Mr Apple has just suggested I replace 'they're' with 'there' or 'their'.... oh dear!)
Radio Wrangler is offline
Old 23rd Oct 2018, 9:08 am   #5
rontech
I used to have a some late 1930's copies of Wireless World and they had advert's for
"Ostar Ganz" valves. I think they were of Czchech or Hungarian origin.
Time flies like an arrow, fruit flies like a banana
rontech is offline
Old 23rd Oct 2018, 9:23 am   #6
Cobaltblue
Cobaltblue's Avatar
Looks like Langrex have at least one for sale.
https://www.langrex.co.uk/products/e...alvetube-lc27/
Mike T
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is online now
Old 23rd Oct 2018, 9:31 am   #7
Nuvistor
Nuvistor's Avatar
A search of 1930’s WW as Ron’s suggestion returns about 30 results.
ID:	171375   Click image for larger version
Frank
Nuvistor is offline
Old 23rd Oct 2018, 10:41 am   #8
Karen O
I would have thought they would be attractive for circuits requiring only a single valve, e.g. photocell amplifier for automatic door. As David pointed out, I can't see it being good for audio when there's (or should that be 'there' ) 240VAC next to the electrodes.
Karen O is offline
Old 23rd Oct 2018, 10:51 am   #9
Karen O
A thought: I wonder if a mod can correct the spelling in the title of this thread to enable future searches...?
Karen O is offline
Old 23rd Oct 2018, 10:53 am   #10
ukcol
ukcol's Avatar
There is some info on radiomusium about the EG100 in the Langrex link.
https://www.radiomuseum.org/tubes/tube_eg100.html
ukcol is offline
Old 23rd Oct 2018, 10:40 pm   #11
Herald1360
Herald1360's Avatar
Maybe "there're" if you're thinking about each of the pesky little 240 volts individually.
I suspect that normal usage would treat "240Vac" as a collective noun so "there's" would be appropriate.
Fowler might say something about it (them?).
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 23rd Oct 2018, 11:02 pm   #12
Radio Wrangler
Default Re: Ostar Ganz valves
OK, OK, There is a potential difference of 240 volts - presumably RMS. Things could get a little complex with DC mains.
Old 24th Oct 2018, 9:33 am   #13
boxdoctor
One complication that springs to mind, is filament migration, where, due the potential between the two ends of the filament, there is sufficient attraction to cause particles of filament material to migrate to the positive-connected end of the filament. An effect that is commonly observed in incandescent lamps fed from a D.C. supply. This would cause early filament failure.
Perhaps something was done to minimise this?. This obviously does not happen when A.C. is used to feed the heater. Tony
boxdoctor is offline
Old 24th Oct 2018, 2:14 pm   #14
Mr Moose
Hello,
I think they were Austrian valves. They were also made in 110V and other voltage versions. They also made sets using their valves.
I rather like their fishnet Faraday cage method of valve screening. http://www.r-type.org/exhib/abi0001.htm
Yours, Richard
Mr Moose is offline
Old 30th Oct 2018, 3:24 pm   #15
boxdoctor
I believe that Germany, and possibly Austria, charged a sales tax at that time, based on the number of valves in the set.
This was a ingeniousl way of avoiding some of that tax. Tony.
Old 31st Oct 2018, 12:50 am   #16
PJL
That LC27 is clearly marked as a rectifier which makes more sense.
PJL is offline
Old 31st Oct 2018, 10:32 am   #17
David Simpson
Karen, as you'll see from "Search", I put out an OG Valve post on the 15th March 2015. It still tested fine on my DC Valve Tester after all these years & produced a decent Ia/Vg graph.
Regards, David
David Simpson is offline
