Old 10th Feb 2019, 3:28 am   #1
vu2nan-nandu
vu2nan-nandu's Avatar
Default Drake TR-4C - PTO problem
In the process of troubleshooting a faulty Drake TR-4C, years ago, the root cause was traced to a non-working PTO.
A visual examination of the mint-condition PCB revealed nothing. Component checks with a multimeter also showed nothing amiss.
Then 'Eureka'! A continuity test showed that the PTO coil was isolated from ground.
A closer examination of the PCB, with a magnifying glass, revealed a dry-solder connection at the ground end of the PTO coil.
Just one solder touch-up and the old workhorse was back in business!
Nandu.
https://nandustips.blogspot.com
vu2nan-nandu is offline
Old 10th Feb 2019, 12:24 pm   #2
Default Re: Drake TR-4C - PTO problem
Excuse me for asking, but what's a PTO coil?
To me PTO denotes Power Take Off as used by tractors.
Station X is online now
Old 10th Feb 2019, 12:42 pm   #3
g4aaw pete
g4aaw pete's Avatar
Permeability tuned oscillator. AFAIK all the '4' series Drake rigs used this tuning method.
Pete
g4aaw pete is online now
Old 10th Feb 2019, 12:51 pm   #4
Thanks Pete.
Old 10th Feb 2019, 1:08 pm   #5
vu2nan-nandu
Hi Graham,
Yes, as Pete says, PTO refers to 'permeability tuned oscillator'. Thanks, Pete!
Permeability tuning is variable-inductance tuning effected by the movement of a ferrite slug in the coil.
Linear tuning is achieved with a variable-pitch coil.
All Drake rigs use a PTO as VFO.
Nandu.
Old 10th Feb 2019, 1:53 pm   #6
Yes. I'm familiar with permeability tuning as it was often used in car radios having mechanical pre-set tuning. I just hadn't heard the term PTO used in this context before.
Old 10th Feb 2019, 2:10 pm   #7
Jon_G4MDC
Jon_G4MDC's Avatar
Thanks for the enlightenment about variable pitch inductor winding to linearise the tuning.
I have some Swan rigs that use these and I always wondered how they got it so good.
I have never taken one apart - maybe I should now
Jon_G4MDC is offline
Old 10th Feb 2019, 2:26 pm   #8
vu2nan-nandu
Thanks, Graham, for rekindling old memories - I plumb forgot about vintage car radios with permeability tuning!
Nandu.
Old 10th Feb 2019, 5:00 pm   #9
vu2nan-nandu
Most welcome, Jon.
Real great rigs were the Collins, Drake & Swan!
Nandu.
Old 10th Feb 2019, 5:13 pm   #10
Drake used a permeability tuned oscillator, the Ten Tec Corsair sports one, but the famous user was Collins i a lot of their professional and amateur classics.
In lieu of a gearbox, a screw thread gave lots of reduction.
Artful variation of the spacing of the turns along the former could give a nice linear tuning scale.
Wear of the screw can be a problem
Radio Wrangler is online now
Old 11th Feb 2019, 12:13 am   #11
Dave757
I have a Drake SPR-4 receiver with a PTO, Unfortunately there is wear
on the threads, and tuning can be a bit of a lottery!
Kind regards
Dave
Dave757 is offline
