3rd Apr 2010, 10:22 am | #21 |
Re: The use of valves in car radios
cheerful charlie, that 'box' contained the power amplifier, which, in the case of your dad's PYE Radio was transistorised, making the set a 'hybrid' type. These were common in the late '50s/early 60s, most used the 12 volt valves (ECH83, etc., mentioned by vinrads). All transistor radios came in during the 60s, many having those push-button tuners you mention.
3rd Apr 2010, 12:49 pm | #22 | |
I know what you mean. A previous owner of my Doblo has fitted a CD radio but wired it up wrong so it loses it's preset station memory when you turn off the ignition. I could easily alter the wiring if I just knew how you get the darned thing out of the dashboard |
3rd Apr 2010, 8:36 pm | #23 |
Until 1971 we were supposed to buy a "radio receiving license" for a radio fixed into a car so many a Trannie, fitted with a coupling coil on its ferrite rod, was balanced on the dashboard and connected to an aerial clipped to the roof gutter. Standardised methods of fitting car radios eventually followed and now, like heaters and aircon are no longer "optional extras". Progress. But what about Digital car radios?
That's another story says the moderator! Got carried away there and forgot to tell 'fidobsa' he probably needs a pair of U shaped release keys to get the set out of the dashboard (what's their propoer name?) Cheers Last edited by Maestro Maker; 3rd Apr 2010 at 8:47 pm. Reason: add note |
3rd Apr 2010, 10:35 pm | #24 | |
I can remember fitting a Hybrid radio in my Mk1 Cortina, something in it was rather microphonic,made an interesting 'ting' when changing stations. Single OC16 output stage, EF98 driver?
Jim |
3rd Apr 2010, 10:47 pm | #25 | |
I was using a valve (hybrid, with OC16 output stage) in my car until 1994 when I was lucky enough to be given a company car. Power demand was 1.5A and I ran it direct from the battery, so it was useable all the time. I did run the battery flat a couple of times, with prolonged listening while stationary with the doors open, but a couple of swings on the starting handle, no problem! |
4th Apr 2010, 12:06 pm | #26 |
Hi all,
Here's a couple of pictures, outside & in, of my Pye TCR 1000 car radio which I've had for many years. It's a bit tatty, but still works well. Four valves with the output transistor mounted on the outside of the back of the case.... |
6th Apr 2010, 10:04 am | #27 |
The Daily mail have published my reply.
This thread has gone OT a few times and has now reached the end of the road, so I'm switching the engine off. |
