27th Mar 2010, 7:17 pm | #1 |
The use of valves in car radios
I've been following a reply to a question in the Daily Mail's questions and answers section.
Does anyone know when Valves were phased out and transistors introduced in Car Radios? My guess would be late 50's early 60's. Many thanks Michael |
27th Mar 2010, 7:27 pm | #2 |
Re: The use of valves in car radios
Transistors were first used in the power output stages in hybrid sets. Valves were retained in the RF and IF stages.
I can't put my hand on the file with early car radio circuits at the moment but I'd go for 1959 or 1960 off the top of my head. Regards,
Brian |
27th Mar 2010, 7:30 pm | #3 |
Michael - I saw that reply too and I'm not sure about it. I reckon that more recently, cars deliberately cut the juice to ancilliaries to give all the power to the starter and also to prevent 'glitching' and corruption of memory data etc.
I think you are probably right about the date.
Andy G1HBE. |
27th Mar 2010, 8:04 pm | #4 |
My opinion too, I'm writing a reply as we speak!
27th Mar 2010, 9:27 pm | #5 |
A couple of Italian makers, Voxson and Autovox, continued to make valve car radios into the early 60s.
Their later valve car radios still had all-valve circuits including the output stage, but used transistorized switchmode inverters to generate the HT. |
27th Mar 2010, 9:34 pm | #6 |
There was a Thread about this last year(?) but I can't find it.
One for the Mods. Alan |
27th Mar 2010, 9:38 pm | #7 |
What an odd way of doing it! If you've got transistors that can deal with enough power to run a loudspeaker via a valve, then they're surely more than capable of driving a loudspeaker directly?!
27th Mar 2010, 9:55 pm | #8 | |
Rich.
27th Mar 2010, 10:56 pm | #9 | |||
The question posed in the Daily Mail is:
My Answer submitted this evening: Quote:
Michael |
27th Mar 2010, 11:17 pm | #10 | |
27th Mar 2010, 11:19 pm | #11 |
Umm,
Andrew2 is correct above. In every car I've had, the radio going off when the engine is cranked is not because of the voltage falling, but it's because the auxiliary circuits are switched off when the ignition switch is moved to the crank position, thus ensuring maximum battery energy is available for cranking. Of course, the radio will also have a permanent live, and actually, this is where all the current comes from - in every modern (post-1990) radio I've had, the "switched live" is effectively just a control input and little current flowed into it. And that's why some can be switched on when the ignition is off (in this mode Ford radios will switch off after an hour). The Sonys I had could be powered from the permanent live (to support cars that didn't have a switched live), and when operated in this fashion, they continued playing happily during cranking. As did two Blaupunkts I had. Though I can't quite remember what the cassette deck did during cranking Cheers, Mark |
28th Mar 2010, 1:54 pm | #12 |
It's an interesting one that - think I'd also put a vote in for early 60s being the point when valves dropped out of mainstream use for car audio from the few examples I've seen.
The arrangements in cars however seem to vary wildly from maker to maker and from model to model. Of the cars available for me to look at here, we've got several examples: Father's car: 2010 Peugeot 207. This has a pretty clever stereo system integrated into about 20 other things in the car. When you turn the ignition off, it switches off - but you can just switch it back on again. This is all disabled when you turn the key to the start position. No idea whether its supply is actually cut of though. 2009 Peugoet 107. Stereo's live as long as the ignition is on - goes completely dead during cranking. ...Car's also under warranty still, so I'm not about to go dismantling the dashboard to check whether it's actually powered down or not though! 1994 Suzuki Cappuccino. Live with the ignition on, but ALL supply lines are cut off when cranking. Same for pretty much everything else in the car - it really does divert everything to the starter. 1995 Lada Riva 1.5E. Live all the time (there's no "accessory" position on this car's ignition. Just off, on and start), not blanked during startup. Radio seems to behave fine though...admittedly the vehicle voltage does only drop a couple of volts...mainly due to a MASSIVE battery though there! Interesting to see the various approaches though! |
28th Mar 2010, 5:05 pm | #13 |
If my memory serves me correctly the Pye 1000 was the first to use a transistor, just one an OC16 as a single ended output stage - sounded very good to. I would say that was about 1960.
28th Mar 2010, 5:41 pm | #14 |
I believe the earliest UK hybrid car radio was the Pye TCR 16 "High Fidelity" model from 1956, ( covered in the 1956/7 R+TV servicing book). This used 3 valves, 12BE6, 12BA6, PCL83, and 3 V30/20P power transistors, one as an inverter for the HT to the valves and two as a 4 watt push pull output stage. I have never seen one of these sets. The Motorola 77M seems to be one of the last valve/transistor hybrids using 12v HT valves in 1962.
Regards, Mick. |
28th Mar 2010, 6:23 pm | #15 |
Interesting stuff. I had always wondered how they got the HT in valve car sets and had thought perhaps they needed an additional HT battery like the portable sets.
28th Mar 2010, 8:54 pm | #16 | ||
This allowed the use of cheap reliable valves instead of exotic and troublesome 12v valves. I have an Autovox radio from 1961 with the transistorized HT inverter and it still works great! |
1st Apr 2010, 9:10 pm | #17 |
Hello, I am assuming you are referring to broadcast car radios. I can't be specific about these, but I do have a HUDSON FM208 4M mobile which still works and this uses valves for the Tx section and transistors for the Rx. The manufacturing date for this set was around 1964/65. I am modyfing the set to work on 2M as we don't (yet?) have 4M here in Holland. 73'Alex,
3rd Apr 2010, 8:58 am | #18 |
I'm talking about in car stereo and radio systems, the sort of car radio/audio system that are either fitted as standard by the car maker or retro fitted at a later stage.
3rd Apr 2010, 9:29 am | #19 |
Hi nobody has mentioned the special valves ECH83 EBF83 these were designed to work on 12 volt ht and with a transistor output stage ,no vibrator or inverter was required, regards Mick. oops just noticed Ritch mentioned them .
3rd Apr 2010, 10:00 am | #20 |
my ten pence worth, from old memories maybe wrong?
My dad's early 1961 reg car had a Pye valve radio fitted. There was a multicore cable going from it to another box which was situ somewhere near the heater blower. On this box was a chunky power transistor with the whole box presumably acting as a heatsink , at the other end of this mysterious box was the speaker output. no idea what that box was all about the radio was brill though, medium wave was so much more suited to the car than crappy FM. His 1965 car radio was all transistor with those brilliant mechanical selector buttons...once again something that worked very well compared to all the nonsense you have to go through today just to find a station and hold it for 10 minutes. |
