Old 30th Jun 2020, 7:52 am   #1
cornwall60s
Default Juli-Corder 999 Reel to Reel
Looking for a bit of advice on an unusual reel I've just picked up dirt cheap as a bit of a project.
Can anybody recommend somewhere to pick up a power cable (UK) for this?
https://***********************/65535/...4bb73ab2a5.jpg
Also, I've yet to take the machine apart but anticipating problems ahead.... Has anybody worked on one of these before? There isn't a huge amount of information available online so they seem like quite scarce machines! If it needs new belts for example, could anybody suggest a suitable belt kit?
thanks in advance!
cornwall60s is offline
Old 30th Jun 2020, 9:31 am   #2
DMcMahon
DMcMahon's Avatar
Default Re: Juli-Corder 999 Reel to Reel
Have not heard of this make, so found an image to see what it looks like.
DMcMahon is offline
Old 30th Jun 2020, 9:34 am   #3
cornwall60s
Thanks David. I wasn't quite sure how to attach to the post, but can see now!
Old 30th Jun 2020, 9:57 am   #4
DMcMahon
DMcMahon's Avatar
From your photo it looks like the mains plug is 2 pin. Ideally it would be good to convert it to UK 3 pin so as to have a safety earth connection using 3 core cable.
Online you can get IEC 3 pin chassis mounted plugs (sometimes called Kettle plugs) in a few variations that can be used with a standard kettle type mains lead.
It depends whether the existing connector can easily be removed and if the new 3 pin connector can be slotted in, may require some minor metalwork changes.
This link shows some of these type of connectors and some have dimensions.
https://www.bing.com/shop?q=iec+chas...4506890C3F09BE
Update - the posted link does not show the dimensional images that were present when I originally viewed it, so some Googling will be required at your end to check on dimensions.
Note - any conversion to the mains wiring/connections should be done by a competent person.
Click on "Images" near top left to get view with some dimensions shown.
DMcMahon is offline
Old 30th Jun 2020, 10:16 am   #5
Lucien Nunes
I think this is the same as on some Revox, Roland and Marantz products. The cable-mounted connectors are scarce but they do exist. If so, although it has only two pins, it is earthed via side-contacts on the connector that engage with the metal body of the inlet. Personally, I dislike cutting bigger holes in equipment to take an IEC connector. I would rather fit a blanking plate with a captive flex secured through a gland, and keep the old connector, so it could be reversed later.
Lucien Nunes is offline
Old 30th Jun 2020, 10:26 am   #6
cornwall60s
Thanks all. Sounds like a trip to the electrician neighbour to ensure this is done correctly, hopefully I can locate a suitable IEC 3 pin chassis that closely fits.
The reel also runs on batteries, so in the meantime I should be able to check it over and get things up and running!
Old 30th Jun 2020, 10:28 am   #7
Alistair D
Alistair D's Avatar
It looks like it could be an IEC C9 connector https://www.plugsocketmuseum.nl/PowerCord1.html
They are available on Ebay as line sockets and ready made leads. Before purchasing you need to confirm the dimensions.
Al
Alistair D is offline
Old 30th Jun 2020, 10:35 am   #8
DMcMahon
DMcMahon's Avatar
So similar but different to this.
DMcMahon is offline
Old 30th Jun 2020, 10:47 am   #9
cornwall60s
Something like this?
Old 30th Jun 2020, 10:53 am   #10
ms660
ms660's Avatar
It looks similar to a standard USA mains connector, Sony used those on some of their tape recorders, TC-630 for instance.
Lawrence.
ms660 is offline
Old 30th Jun 2020, 11:11 am   #11
DMcMahon
DMcMahon's Avatar
Attachment 209877
I guess this is a IEC C9 which may fit but would not provide the earth connection.
DMcMahon is offline
Old 30th Jun 2020, 11:21 am   #12
Lucien Nunes
The Revox / Marantz type is as shown by David. AFAIK neither the USA NEMA size nor IEC C9 will fit, both are physically too wide.
Old 30th Jun 2020, 11:25 am   #13
DMcMahon
DMcMahon's Avatar
My one off a very old Grundig may have narrower spacing across the 2 pins.
DMcMahon is offline
Old 30th Jun 2020, 11:27 am   #14
ms660
ms660's Avatar
They were ten a penny so to speak when I worked for Sony.
Lawrence.
ms660 is offline
Old 30th Jun 2020, 11:44 am   #15
DMcMahon
DMcMahon's Avatar
Not familiar with the Sony connector, does it provide the earth connection, the TC-630 schematic does not show an earth connection to the the 2 pin AC receptacle.
DMcMahon is offline
Old 30th Jun 2020, 11:59 am   #16
ms660
ms660's Avatar
No mains earth connection on the ones I used to service across the pond, the type of mains input connector used on the TC630 was used on other Sony models and by many other Japanese manufactures.
Lawrence.
ms660 is offline
