29th Oct 2008, 3:04 pm | #1 |
Valve sparking
I am repairing a 1938 Clarville (France) radio. I have changed the e caps but when it is switched on, the set is dead but the valve EBL1 (double diode pentode) flashes with violet sparks inside the glass. There is also a corresponding noise from the speaker. Does this indicate the demise of the valve or could this be the result of something else?
The lineup is EK2 octode,EF9 pentode,EBL1 double diode pentode,1882 fw rectifier. |
29th Oct 2008, 3:18 pm | #2 |
Re: Valve sparking
Well it won't do it much good! Are you sure first of all that the valves are in the right place. Better people have been caught out.
Check everything out thouroughy, especially the output transformer. Also check all your wiring and the wiring on the valve bases. Then bring it up on a variac. And get another EBL1. Cheers, Steve P.
29th Oct 2008, 3:49 pm | #3 |
Re: Valve sparking
Sadly, it's almost certain to be the valve.
Paul |
29th Oct 2008, 4:12 pm | #4 |
Re: Valve sparking
Can I butt in here, please?
If a rectifier valve sparks internally very occasionally, with no other symptoms or signs of distress, is it OK to leave it, or is there a risk of something nasty happening? Nick. |
29th Oct 2008, 4:13 pm | #5 |
Re: Valve sparking
If a rectifier sparks internally, I would check around it and then change it. But that's me.
Cheers, Steve P.
29th Oct 2008, 4:18 pm | #6 | |
Re: Valve sparking
Paul |
29th Oct 2008, 4:58 pm | #7 |
Re: Valve sparking
Back to the original question....is the EBL1 similar to the EBL31 but side contact? If so it's probably the valve. As this is a high-slope valve, the pentode is driven straight from the detector so it doesn't have the usual pre-amp stage...therefore no coupling capacitor from a previous anode....so no positive volts on the grid due to a leaky cap. I've had several EBL31's give this problem (and EBL21's) and a replacement valve has sorted it. One of them gave a very impressive firework display when tapped!
Rich.
29th Oct 2008, 5:06 pm | #8 |
Re: Valve sparking
The EBL1 and EBL31 are identical apart from the base and the top cap. EBL1s are much easier to get.
Leon. |
29th Oct 2008, 6:29 pm | #9 |
Re: Valve sparking
I will be getting a new EBL1. So far I have not discovered the model name as the place where it should be has not been stamped.
30th Oct 2008, 12:07 am | #10 |
Re: Valve sparking
Its a common problem with the EBL31 (and I presume the EBL1 since its the same valve on a different base) its down to an internal short on one or both of the diodes. You can disconnect the internal diodes and replace them externally with a small signal diode of the 1N914 variety, you can use the pentode section normally. You might experience some drop in output but hey, its a fix. I've done this on a couple of sets which have had faulty EBL31's. Rod Burman on the IOW was selling EBL31's for about £30 (and that was a couple of years ago) so its worth trying the diode dodge.
mark |
30th Oct 2008, 1:25 am | #11 |
Re: Valve sparking
If ANY valve does anything like this, check the circuit thouroughly before fitting a replacement and powering up. It could be expensive otherwise.
Cheers, Steve P.
30th Oct 2008, 12:16 pm | #12 |
Re: Valve sparking
The potentials associated with the diodes in the EBL1/31 are insufficient to cause visible sparking inside the valve. The electrodes responsible will be either the anode or g2 and shorts here place the rest of the set at some risk - especially the (probably complex) output transformer.
Leon. |
30th Oct 2008, 2:33 pm | #13 |
Re: Valve sparking
This is a circuit (Philips 650A) of the EBL1 output (with detector AGC diodes) valve V4. The grid coupling cap should be changed if a new valve is fitted.
30th Oct 2008, 3:32 pm | #14 | |
Re: Valve sparking
Geof |
30th Oct 2008, 4:22 pm | #15 |
Re: Valve sparking
This is the coupling capacitor which provides the AC feed to the AGC diode - typically 50 pF.
This is absolutely standard pre-war superhet circuitry and the AGC is derived from this point in order to leave just one set of IF tuned circuits (second transformer secondary) out of the AGC loop. This makes the receiver far easier to tune - if you put all of the tuned circuits inside the control loop the AGC flattens the tuning response. As designed, the remaining tuned circuit gives the set a sharp response despite the AGC action. The coupling capacitor will be either a slilvered mica or a ceramic type. Neither is prone to failure. Leon. |
30th Oct 2008, 9:28 pm | #16 | |
Re: Valve sparking
Geof |
30th Oct 2008, 11:28 pm | #17 |
Re: Valve sparking
There are two main reasons for combining the diodes with the output valve. It is possible to make a very acceptable "short" superhet without an AF preamplifier stage given the high slope of devices such as the EBL1.
A more fundamental reason relates to AGC delay voltage. For an AGC system to operate properly, its action should be delayed until signals of a strength such that overload is about to occur are received. If this is not done, any significant signal will reduce the gain of the receiver. The voltage delay is usually achieved by returning the cathode of the AGC diode to a positive potential so that rectification of the signal to produce AGC voltage will not occur until about the point at which that carrier voltage is developed. A very convenient source of delay voltage is the cathode bias potential for the output valve. In a short superhet, this voltage usually has to be increased to around 15V for the delay voltage to be optimal, so the bias resistor is split in order to allow the output section of the valve to be correctly biased. Using the IF amplifier (EF9) would not give any significant delay as its cathode bias voltage is too small. A further problem is that the EF9 is itself AGC controlled, so the delay voltage would shift as the AGC came into operation - not a good idea. Leon. |
31st Oct 2008, 12:39 am | #18 |
Re: Valve sparking
Thanks Leon, you give a very good description of the valve operation. I knew about the delayed AGC but not quite the reason for it to be carried out in the output stage diode, apart from it not being a good idea to develope the AGC from the controlled valve, back into the same controlled valve. This would make for a very strange unstable operation. The EBL1 is quite an incredible valve being the whole of the AF stage.
Geof |
31st Oct 2008, 2:40 pm | #19 |
Re: Valve sparking
I'd think that trying to put the diodes in the IF amplifier bottle might cause instability - after all, the diode anodes are handling several volts of IF, and capacitive coupling to the grid of the valve could well cause significant regeneration. Putting the diodes in the output valve envelope would remove this possibility.
I'd expect that the EBF80 exists because post-war, button-based valves have such a lower inter-lead capacitance that the idea is workable. Finally, hearing that the EBL1 is prone to internal shorts, is this a consequence of it having to be high slope to suit its intended purpose? A fine, close-pitch grid, situated very close to the cathode? |
31st Oct 2008, 5:46 pm | #20 |
Re: Valve sparking
To be fair, in my experience I can't say the EBL1/31 is particularly prone to internal shorts. The main problems I've found with this device have been caused by thermal fatigue of the soldered joint on the top cap causing noise (just re-solder it) and loose metallising.
It's quite reasonable to assume that a high slope valve will have close electrode spacings but in my experience, Philips and Mazda both did a good job. To generalise, I would say I've seen more short superhets with their original output valves than standard superhets. This is doubtless because in a short superhet, a leaky grid coupling capacitor biases the valve off with a negative potential from the detector, rather than turning it hard on with a highish voltage from the pre-amp anode. There was actually an EBF2/32 made. If you use a back bias arrangement to provide the AGC delay, this is quite a workable scheme. The sections of these valves were well screened. Leon. |
