2nd Sep 2018, 1:09 pm | #1 |
Garrard 35SB
Hi folks,
I recently bought a Dynatron music centre with a Garrard 35SB turntable and I have two problems: 1. The turntable runs slow (about 31rpm & 42rpm according to an app on my phone) despite me fitting a new belt. Is anyone aware of any known trouble spots with this deck where I should start first or do I need to do a complete strip-down and service? 2. The cartridge fitted to the headshell isn't the same as the one described in the manual that came with the machine, so I'm having trouble sourcing a replacement stylus. Unfortunately, the manual doesn't give a number for the original cartridge. Does anyone know which model might have been fitted to this deck? Thanks for your help! |
2nd Sep 2018, 1:40 pm | #2 |
Re: Garrard 35SB
We tended to fit the Goldring G800 Moving Magnet cartridge, but this sometimes got substituted for a Shure M75. A photo would help. In terms of your speed readings, these are not that much off spec. In spite of its pretentions, it's still a budget turntable. If you do use any lubricant in the obvious places, use sewing machine oil, not WD40.
Edward. |
2nd Sep 2018, 2:37 pm | #3 |
Re: Garrard 35SB
That's useful info, Edward. A bit of further online research has suggested the cartridge might be a Vernitron V100....
My hearing must be better than I thought (or the app on my phone not very accurate) as I can definitely hear that the turntable is running slow. I shall start with some gentle lubrication... |
2nd Sep 2018, 4:35 pm | #4 |
Re: Garrard 35SB
This will actually be a Sonotone V100 cartridge. Don't put any oil near the belt or pulleys. Maybe only on the centre bearing. I still think your deck is performing within its design limits.
Edward. |
2nd Sep 2018, 7:06 pm | #5 |
Re: Garrard 35SB
If it's still slow once you've lubricated it (and I suspect that it will be, as Edward implies), you could try a bit of heatshrink sleeving over each of the motor pulley steps.
2nd Sep 2018, 7:36 pm | #6 |
Re: Garrard 35SB
Is the new belt too tight? That will slow it down a bit.
2nd Sep 2018, 10:49 pm | #7 |
Re: Garrard 35SB
I don't recall turntables running slow when in current usage. Perhaps the proliferation of mobile phone "aids" is creating doubt here. Do you have a stroboscope?
3rd Sep 2018, 12:50 pm | #8 | |
Re: Garrard 35SB
The caveats are of course that the drive surfaces are clean, the motor is in good order and the belt is the right size. Sort all these out and it should run at the right speed without any issues. |
