#21 |
The one on the left has a NC electromagnetic microphone, probably much the same design as the one we've been discussing. The one on the right has a regular moving coil dynamic type, same design as the giveaway types with old cassette recorders but higher quality and NC.
#22 |
Ah, now I found it, how these mics were available for Amplivox headsets, see attached. I read in an earlier post about the Airmed/CCI Airlite 62, which led me up the garden path - bit of confusion!
I have an Amplivox Astrolite in the garage too, I'll go and dig it out.
www.scottbouch.com |
#23 |
Ok, so here is my Amplivox Astrolite, with yet another different mic type!
Don't know why this has a DIN plug, and no mic switch in the cable, not sure of its intended purpose. Also not yet stripped apart the earpiece to look for an amplifier like yours.
#24 |
The microphone in your Astrolite is a standard, i.e. not NC, moving coil dynamic type. Impedance 500 ohms. The DIN plug suggests this headset was intended for a language lab. Our Tandberg language lab at my high school (nearly 40 years ago) used Astrolites but with the Nexus US spec NATO plug.
#25 | |
![]() Quote:
He only used the radio once to land too.
#26 |
Another mic, modern RACAL Atlantic headset, with another type of noise cancelling mic. I also have this type of mic element on booms for Mk4 flying helmetsfrom the 90's
#27 |
And the Ampluvox /RACAL Jetguard, with yet anothrr noise cancelling mic. This type of mic also appears on flying helmets.
#28 |
The microphone on the Atlantic headset is a moving coil NC type, 200 ohms. Also available in grey! I've no idea about the other one.
#29 |
These all should be 200 Ohm dynamic for compatibility to aircraft with NATO sockets.
Having used noise cancelling mics in an EE Lightning on engine testing, they still pick up a lot of noise. Much better to use an oxygen mask or throat mic.
#30 |
Hello Scott
Is there a schematic for the Airmed amplifier adapter that you mentioned on earlier post in this thread? I am interested about it for connecting an airlite 62 to a Collins 618T By default the Collins 618T uses a carbon Microphone with an 18V DC on the line I sent you a PM Thanks Thierry
BVWS Member. |
