9th Nov 2013, 5:58 pm | #1 |
Bakelite cabinet crack re-inforcement
I am now the proud owner of Lowemission's basket-case (sorry Julian!) Ekco AC76 and am considering how best to treat the crack. See picture in
https://www.vintage-radio.net/forum/...d.php?t=100435 The crack is clean and tight, and having read through all the threads on bakelite crack repair it seems the best thing to do is to run some good quality superglue into it and hope for the best. I have located some supposedly thin superglue for the task but would appreciate any advice from members more experienced than I. The case in this area is only about 3mm thick and I am tempted to epoxy in a metal reinforcing plate on the inside to make sure it doesn't break apart again. Is that worthwhile? Will I get problems with differential expansion of bakelite, epoxy, and metal? I know this will look awful but there is no point in trying to hide the crack. There's a lot to do on this set and this is going to be the first of many posts. Watch this space!
Regards, Richard, BVWS member |
9th Nov 2013, 6:10 pm | #2 |
Re: Bakelite cabinet crack re-inforcement
I have used superglue to repair bakelite with great success, I used car fibreglass repair paste to reinforce the rear of the repair, and have had no problems with this method.
I don't think you need to worry about heat in that area of the set. As yours is a valuable set, I would firstly experiment on a scrap cabinet to find the best/neatest way to do it. Mark |
9th Nov 2013, 6:28 pm | #3 |
Its important to stabilise the crack so it doesn't continue to the front of the cabinet and I've found superglue to be the best thing for that.
Try to open the crack slightly when applying the glue for the best adhesion but take care not to unduly stress the bakelite and make the crack worse whilst doing so. Often superglue alone will be sufficient do the job but internal reinforcement with epoxy wouldn't hurt either. I shouldn't worry about expansion issues due to heat, the crack is low enough down for that not to be a concern here. Regards |
9th Nov 2013, 6:31 pm | #4 |
I too have used fibreglass to strengthen the inside. I used the mat rather than the paste but it might not give as neat a finish.
9th Nov 2013, 6:40 pm | #5 | |
Take a look at the bakelite cabinet I had to deal with on my Ekco AD75 set here; Ekco AD75 released c.1940 & 1946 for a real basket-case! But it didn't turn out too bad in the end I think? By the way, the crack running in the left hand foot (as viewed from the rear) was stabilised with superglue only. Good luck with your AC76! Regards |
10th Nov 2013, 9:12 am | #6 |
Thanks gents, it sounds like epoxy or glassfibre putty is the way to go. At least it will be easier to remove if the need ever arises. I have read good reports on Milliput, is it suitable for mechanical strengthening as well as a filler?
That's a good restoration, Robert. I am very impressed. Your phrase " it didn't turn out too bad in the end" is very telling. There's obviously a lot of trial and error and false starts before you get to a good result. And by the way, 'tis true the cabinet is in one piece, but the rest of the radio had been dismantled and a basket would have been useful to get it all in the car
10th Nov 2013, 11:50 am | #7 | ||||
Regards |
10th Nov 2013, 12:16 pm | #8 |
I have purchased some "Roket Hot super-thin penetrating cyano glue" from my local model shop and am going to try that:
http://www.deluxematerials.co.uk/pages/superglues.htm The thing that worries me is how do I know if the superglue-only joint is strong enough? I guess if it survives all the polishing stages and putting the chassis in and out several times then it is.
10th Nov 2013, 12:50 pm | #9 |
I've always found bog standard superglue (Loctite's version) does the trick. I apply the glue, let it overflow on the visible side of the crack a bit, hold everything in place until it starts to stick (don't keep pulling it apart to see if it's stuck!) then leave it overnight somewhere warm. Once it's all set nicely I then set about it with VERY fine wet & dry paper, P600 would probably be the coarsest I'd use (although I have used P400 before, it makes more work for yourself.) sand the surface flat, then polish it with your usual Bakelite polish. On a large cabinet like this I'd probably use some fibreglass on the inside just to give it a bit of extra strength, I've got 2 AC76's in battered conditions, and I've noticed the cabinet's are quite flexible, which could cause the repaired crack to pop open again if it was flexed in the right direction. Saying that, I have used just supeglue on it's own on a few sets and not had any cracks reopening. If you do need some fibreglass, you can get a kit from Halfords called 'David's Fastglass', which I've used before with success. Regards, Lloyd. |
10th Nov 2013, 2:48 pm | #10 | ||
Bakelite is porous due to the filler material is contains, usually sawdust, and will happily absorb water if allowed to sit in it too long whilst you are cleaning it to the detriment of the polished finish. However, with superglue it allows it to seep into the fibrous filler material and form a good bond. Quote:
It's not always possible to avoid applying glue to the polished side though and Lloyd's method of P600 paper or higher and then wax polishing is the way to go on such occasions. Regards |
13th Nov 2013, 2:08 am | #11 |
I'm not sure if this is the best approach in this case, but a technique I've used very successfully on a number of occasions to stop crack propagation is to drill a small hole in the material slightly ahead of where the crack presently stops. If the crack continues to propagate, then when it reaches the hole the stress is the spread over the circumference of the hole and not concentrated in the microscopic crack tip. This method really does work, but is not always attractive when appearance matters.
13th Nov 2013, 2:27 am | #12 | |
But for a bare unpainted bakelite case, especially one for a round Ekco, is not advisable if the monetary value of the set is to be maintained. Regards |
