Old 16th Dec 2013, 4:12 pm   #61
Mikey405
Mikey405's Avatar
Default Re: Downloadable Test Card DVD
Thanks Tas and Joe.
I'll have a think about TCW Joe. Tip-top lights Tas and thank you for the picture too.
Kind regards.
From Mike.
G7TRF
Mikey405 is offline
Old 16th Dec 2013, 4:29 pm   #62
bobbyball
bobbyball's Avatar
Just dowloaded it onto the laptop but realise I haven't a burner program installed at the minute, D'ohh!! Good effort as always, Mike, all the Best!!
EDIT: Burned it now, works very well (of course!!)
Robert
bobbyball is offline
Old 22nd Dec 2013, 3:03 pm   #63
Mikey405
Mikey405's Avatar
Brilliant. Glad it works well Bobby.
Kind regards.
From Mike.
G7TRF
Mikey405 is offline
Old 3rd Jan 2014, 9:57 am   #64
Doctor Hue
Doctor Hue's Avatar
Originally Posted by Mikey405 View Post
download and burn using your favourite .ISO burner program.
Thanks for the iso.
I've discovered that using "VLC media player" I don't even
have to burn a physical disc. It will just play the iso like a DVD.
VLC is available for Linux, Mac and Windows
( I'm using Linux )
Doctor Hue is offline
Old 24th Mar 2014, 8:47 pm   #65
Radio Tech
Radio Tech's Avatar
Hello everyone,
This DVD that has the test cards on it, as it is an iso file how do I get it in a bootable dvd or even in dvd format so that it can be used via a dvd player. I tried downloading it but as it is an iso file it will not run or even play, from what threads that I have read it seems some have managed to use it.
best wishes
Ken
Radio Tech is offline
Old 24th Mar 2014, 9:23 pm   #66
Courtney Louise
Courtney Louise's Avatar
use your dvd recording software to load an image then select the ISO and burn, it will record it as a playable DVD
Life is long, life is short, both of these a daunting thought.
Courtney Louise is offline
Old 24th Mar 2014, 9:46 pm   #67
Duke_Nukem
Duke_Nukem's Avatar
You can use ImgBurn to burn the ISO as a video DVD.
TTFN,
Jon
Duke_Nukem is offline
Old 8th Apr 2014, 12:40 pm   #68
Radio Tech
Radio Tech's Avatar
Hello Mike
I like the way the Test Card DVD layout looks, well done I say and thank you
Ken
Old 1st Nov 2014, 2:57 pm   #69
BGmidsUK
BGmidsUK's Avatar
That's fantastic Mike, thanks for your efforts! It's time I set up somewhere to resume my projects where the cats won't get in to harm's way. These test patterns will be very useful.
Brian
BGmidsUK is offline
Old 23rd Nov 2014, 2:22 pm   #70
Mikey405
Mikey405's Avatar
My apologies for the late reply Dr Hue, Ken and Brian. I'm glad it's of use - I think it's about time I updated it so watch this space.
Kind regards.
From Mike.
G7TRF
Mikey405 is offline
Old 13th Feb 2015, 1:06 pm   #71
Nicklyons2
Nicklyons2's Avatar
Mike, I have found some strips of 16mm film which were part of a telecine line up test loop years ago. These include two versions of Test Card 'C' including the 'colour' version. There are about 10 frames of each so 1 at least should be a good one. Are these of any use to you to scan? my scanner is good but not particularly high res. If you have the correct gear and can make use of them please let me know - before I lose them again!
Nicklyons2 is offline
Old 13th Feb 2015, 8:25 pm   #72
Mikey405
Mikey405's Avatar
Hi Nick.
That would be brilliant - I do have a slide scanner which will go up to a very high resolution so it'd be great to scan those in. I'll send you a PM.
Thanks Nick.
Kind regards.
From Mike.
G7TRF
Mikey405 is offline
Old 14th Feb 2015, 2:09 am   #73
BGmidsUK
BGmidsUK's Avatar
The DVD has been used to replace the custom Test Card C on one of my Aurorae with the correct TC-D with BBC-1 405 LINES .. the one I've wanted to use for ages but couldn't find a decent copy. The results are excellent. TC-J is currently in use on 625 as I'm still setting up my distribution system and don't yet have enough receivers for all the channels, the player turned its motor off after a short interval.
I wonder if it would be possible to include the IBA:CH4 card? I have fond memories from when Channel 4 first started, finding this on the dial, and later on using it to set up the contrast properly on my Citizen TC-53 as it had larger greyscale blocks. I don't think I have any VHS recordings of this any more.
The colour-bar used by Five, being the last analogue channel, would also be good to have. I'm sure I could replicate the multipath and co-channel interference from the early days before Waltham started transmitting and make a recording for nostalgia purposes! I might actually have an off-air recording of this somewhere.
I'd like to do this myself but unfortunately my main PC is out of order and Nero is on that machine.
Brian
BGmidsUK is offline
Old 16th Feb 2015, 5:29 pm   #74
Mikey405
Mikey405's Avatar
Hi Brian.
I'm glad the test card disc is proving useful. I was thinking of including the ETP-1 test pattern on the next disc along with one or two other patterns Si watch this space.
Thanks Brian.
Kind regards.
From Mike.
G7TRF
Mikey405 is offline
Old 26th Oct 2015, 11:27 pm   #75
greg_simons
greg_simons's Avatar
Great job, Don't ever recollect seeing those high frequency gratings so sharp when I was servicing this stuff for real!.
greg_simons is offline
Old 16th Jan 2016, 9:35 am   #76
mcousins
Thanks Mike!
That's awesome, who would have thought that watching test cards would become more interesting than what's actually on TV? Well here in Australia anyway...
Thanks & belated happy new year
Mark - Perth, Australia
mcousins is offline
Old 2nd Jul 2016, 9:26 pm   #77
dtvmcdonald
I'd love to get ahold of some high resolution png or bmp or even in a pinch max quality jpeg scans of some of those things, so I could use in the US.
I would just play them in my picture-playing Bluray player or for B&W use my HackRF to get 441@60i for my prewar US sets.
I have a burned copy of the dvd but for some reason none of my players
can get to the table of contents. Some of the tracks can be played by
randomly pushing buttons, however, including ones unequivocally 405 lines.
So I know the dvd itself is OK. Different players access different things.
dtvmcdonald is offline
Old 3rd Jul 2016, 12:14 am   #78
ntscuser
ntscuser's Avatar
Originally Posted by dtvmcdonald View Post
I have a burned copy of the dvd but for some reason none of my players can get to the table of contents.
You might want to try an earlier version of the DVD? They work better for me in my player.
Classic TV Show Theme Tunes
ntscuser is offline
