Old 30th Jun 2021, 5:32 pm   #1
Murphy Maniac
Murphy Maniac's Avatar
Default Help needed with Smiths/Radiomobile Type B Amp
I am in the process of re-building a Smiths/Radiomobile Type E amplifier unit from a P4 Rover. This amp is the same as Type B with the exception of a couple of extra components not related to my query.
I want to convert the unit to Negative Earth operation, which appears simple enough except for the instruction to remove R123 and C121.
My questions are:
a) What are R123 and C121 doing there in the first place?
b) What happens to R116 and R117, are they still needed?
c) If R116 and R117 are left in place, do I just remove the wire which leads to the junction of R123 and C121?
R118 and R119 (both 47k) lead to the grids of a pair of N78's in push pull.
Apologies for being dim, but push/pull always leaves me confused.
Thanks.
ID:	236820   Click image for larger version
Geoff. (BVWS Member)
Murphy Maniac is offline
Old 30th Jun 2021, 5:33 pm   #2
Murphy Maniac
Default Re: Help needed with Smiths/Radiomobile Type B Amp
Sorry the pictures are on their side again, this always seems to happen to me!
Old 30th Jun 2021, 10:56 pm   #3
Herald1360
Herald1360's Avatar
R123 and C121 provide~ -6V grid bias for the output pair from the potential divider provided by their series heaters across the -12V car supply when the set is used in a +ve earth car. When -ve earth supply is used, the added RC in the chassis connection from the output transformer provides cathode bias instead. (R123 and C121 would have provided positive bias otherwise).
For this to work I believe the junction of R116 and R117 should be taken to chassis, not left floating when R123 and C121 are removed. This snippet seems to be missing from the datasheet!
It's an interesting circuit using cathode coupled feedback from the output transformer a la QUAD II.
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 1st Jul 2021, 12:26 pm   #4
Murphy Maniac
Hi Chris,
Thank you for that explanation, it is becoming clearer to me now, I had wondered why the extra components in the tag 2 connections of socket 102 were necessary. I had not even noticed the cathode coupled feedback from the output transformer, this is something completely new to me.
By connecting the centre of R116 and R117 to chassis, are they effectively acting as grid leaks for V104 and V105?
Old 1st Jul 2021, 7:41 pm   #5
Herald1360
Herald1360's Avatar
Yes, they are the grid leaks for V104 and V105 in cathode bias mode. In the fixed bias (+ve earth) mode they couple the negative bias from R123/C121 to the grids.
R118 and R119 are grid stoppers for the output valves to stop them from taking off at RF, they'll be needed either way (+ or - earth).
....__________
Old 1st Jul 2021, 8:29 pm   #6
Murphy Maniac
Lightbulb Re: Help needed with Smiths/Radiomobile Type B Amp
Many thanks for the explanation, things are looking less intimidating now. I will probably be back as the job progresses.
