1st Jun 2021, 11:11 am | #21 |
Re: HMV 501 Radiogram issues
Just to note there's an error in the Trader sheet version, the voltage drop across R12, either the voltages are wrong or the value of R12 is wrong.
Lawrence. |
1st Jun 2021, 11:35 am | #22 | |
The only option here is to go through the entire radio checking against the 'chosen' circuit and adding component values. Whilst doing this the measured values can be checked against the component markings. Until that is done it will not be possible to tell if the valves are OK. |
1st Jun 2021, 11:46 am | #23 |
1st Jun 2021, 3:10 pm | #24 |
As I said before, I am using the service manual from Radio Museum. There are 4 sheets, but if you look at the two marked 435, 501 this is where I am getting component values from. I have noticed that some of the resistors in the set do not tally with the sheet. Strangely, R14 was missing when I got the set. It is now in place. I printed out the data sheet for the MS4B tube and will probe that one today and get back. This is the type that has the anode at the top of the glass bulb. I will try and find a plastic cap for that instead of just a bare metal clip. Michael |
1st Jun 2021, 3:21 pm | #25 |
Does your receiver have a variable capacitor reaction control (VC4) ?
Lawrence. Last edited by ms660; 1st Jun 2021 at 3:29 pm. Reason: word change |
1st Jun 2021, 4:57 pm | #26 |
The missing R14 would mean it started off life more like the Trader version but probably with R3 and C9.
Isn't VC4 the aerial trimmer but it is not included in the Radiomuseum parts list and would be C18 in the Trader sheet. I still feel the circuit and values need to be checked against a 'master' circuit diagram before any more work is done. My preference would be to use the Trader sheet as the reference. The Trader makes reference to 2 parallel 4uF capacitors making up C9. Last edited by PJL; 1st Jun 2021 at 5:07 pm. |
1st Jun 2021, 7:20 pm | #27 |
Please advise where I can get hold of the trader sheet that you refer to. Maybe it's better, I don't know. Anyway, voltages at V1 on MW are as follows: Anode 159v Screen 20.5v Cathode 0.2v Some resistors are of different values to that on my list. See attached. The white resistor is 25kOhm. On my schematic it is listed as 10k (R3) The bank of resistors in the image I have checked in circuit and they all check out. With the set off and in gram mode, the resistance of the cathode of V2 to chassis is about 1.1MOhm. Rgds Michael. |
1st Jun 2021, 8:09 pm | #28 |
https://www.service-data.com/product...48/3615/t13548
V2 cathode resistor (1K) R10 on the Radiomuseum circuit must be faulty. |
2nd Jun 2021, 12:20 am | #29 |
Lawrence, I see what you mean about VC4 in the Radiomuseum circuit in the regeneration path. I am beginning to think the radiomuseum circuit illustrates a modified version as the connections to VC4 are marked with x's perhaps inferring that the aerial tuning capacitor should be rewired to this position.
2nd Jun 2021, 8:23 am | #30 |
Sorry, I forgot to mention that VC4 is present but not in the position it is on the schematic.
It is connected directly to the antenna input. |
29th Jun 2021, 9:13 pm | #31 |
HMV 501 still having trouble
Guys, I created a post some weeks ago regarding this radiogram I am restoring for a customer.
The original HMV No.15 headshell was open circuit and could not be repaired. The Colaro headshell replacement also has issues upon closer inspection. There are two steel pieces that fit around the coil. One has one of the tiny magnets missing, see attached. There is a larger magnet that sits on top of the steel pieces/coil. I am getting no audio output from the gramophone. If I gently touch the headshell towards the centre of the platter there is a small amount of sound, but not much. The original loom had the ground wire connected to one of the coil wires. I have made a new loom and disconnected that. I can feed a test tone in to the amplifier and can hear it. So I know that the pickup is the issue here. On a differeent note. I am still getting 6v at the cathode of V2 in gram mode. I have even fitted a replacement MH4 tube and it is still the same. It could be the valve base that's at fault here. I am only familiar with the octal and 9 pin bases in most sets I encounter. Please advise what type of valve base this set uses and I will look out for a replacement. Having measured the resistance of the cathode pin (with tube fitted) to ground I seem to be getting erroneous readings I want to know if any member has a HMV No.15 headshell for sale that works. I will place a post in the wanted section for this if need be. Rgds Michael |
29th Jun 2021, 9:37 pm | #32 |
Re: HMV 501 still having trouble
Hi Michael, the MH4 valve according to radiomuseum has a B5 base, which I understand is essentially a B4 with a centre pin
I suppose you could ask here to start with, but if you don't find any you can buy valve bases from China. The one in the picture should do, but I've never tried them myself. Hardly a risky purchase at that price though. Good luck Gabriel |
30th Jun 2021, 9:08 am | #33 |
It seems unlikely to be the valve holder. You need to fix the high cathode voltage before worrying about the cartridge.
Can you give us the MH4 anode, cathode and grid voltages when in gram mode. From Trader 563 have you checked the value of R8 and replaced C10? |
30th Jun 2021, 8:22 pm | #34 |
Ok, I will certainly do some more voltage/resistance checks tomorrow when I've got the chassis out (again)
I now also have a second MH4 tube for side by side comparisons. I will get back to you in due course. BTW, all caps and resistors that I can see have been replaced with new components. The more I study this chassis the more I think that is built to the smaller of the two schematics on the sheets I have taken from the Radiomusem. The power supply is slightly different on the smaller one, so I may rework it. Rgds Michael |
1st Jul 2021, 7:34 pm | #35 |
I have taken chassis out and now have the following readings: V2 in gram mode: Anode 169v Cathode 6.2v Grid 0v Michael |
1st Jul 2021, 9:47 pm | #36 |
According to the trader sheet, R8=1K, R9=10k AND R10=50K.
That suggests there is 6.2mA flowing through R8. V2 has -6.2V between grid and cathode so we would expect it to be cut-off. This is supported by the anode voltage of 169V (trader says 70V) which is higher than the Trader V1 anode voltage. The 6.2mA is therefore not coming from V2 anode. R4 could be responsible for the current but V1 should also be cut-off. The intervalve transformer primary is the only other connection to R8 but that is DC isolated by C10. So... 1. Measure resistance from V2 cathode to chassis (should be 1K) 2. Pull V1 and measure V2 cathode voltage 3. Confirm you have replaced C10 4. Check your wiring and post a picture here |
2nd Jul 2021, 8:33 am | #37 |
I have some more readings: Resistance from V2 cathode to ground, no reading. V2 anode voltage 166v V2 cathode voltage 6v with V1 pulled and not pulled. From the image you can see the two orange caps which are C6 and C11 Rgds Michael. |
2nd Jul 2021, 9:56 am | #38 |
The gram input will not work without R8 (1K).
R8 is one of the ones in the cylindrical box. Measure R8 resistance between the pins on top of the box and check continuity to V2 cathode and ground. Having never worked on one of these I am not sure how easy it is to access the resistors in the box. |
2nd Jul 2021, 10:05 am | #39 |
Seem to have been here before (Post#16):
https://www.vintage-radio.net/forum/...d.php?t=180685 Lawrence. |
2nd Jul 2021, 11:56 am | #40 |
Threads merged.
