Old 11th Mar 2021, 1:16 pm   #1
stevehertz
stevehertz's Avatar
Default Marconi P20B questions
On a Macaroni P20B portable..
See photo 1. There's a small black oblong fibre plate through which two white wires pass. There's a nut missing from the bolt. Is that all that's missing? just replace the missing 6BA nut?
See photos 2 & 3. Someone has cut off the four pin battery connector plug. I need to know the positions of the black, red, white and blue wires for resoldering purposes. If you know this, please refer to the side of the plug where the wires are inserted.
Finally, I don't suppose anyone has got a donor set for parts as the circular dark brown dial scale is damaged on mine.
Thanks!
ID:	228884   Click image for larger version
ID:	228885   Click image for larger version
stevehertz is offline
Old 11th Mar 2021, 2:01 pm   #2
ms660
ms660's Avatar
Default Re: Marconi P20B questions
https://www.vintage-radio.net/forum/...6&d=1256665399
Red = HT+
Black = HT-
Blue = LT+
White = LT-
So far as I can make out.
Lawrence.
ms660 is offline
Old 11th Mar 2021, 2:02 pm   #3
snowman_al
snowman_al's Avatar
Default Re: Marconi PB20 questions
Just a 6BA nut, not even a small washer...
No battery plug on mine either, but Red is +ve HT, Black is -ve HT, Blue is +ve LT and White is -ve LT if it helps.
And an old thread here with a diagram https://www.vintage-radio.net/forum/...92&postcount=3 (#7 I think) but several other results for B114 battery replacement.
Alan
Never Leave Well Enough Alone...
snowman_al is offline
Old 11th Mar 2021, 2:33 pm   #4
stevehertz
stevehertz's Avatar
Excellent, thank you gentlemen.
Now, just that dial face needed..
