Old 13th Aug 2019, 8:47 am   #1
stevehertz
stevehertz's Avatar
Default Connector suggestions wanted
I have a long wire external AM aerial. Inside the house I want to connect it to various rooms and sets by way of connection and simultaneous isolation. I will use a simple plug and inline socket system to do this. I'm looking for suggestions for a suitable small inline plug and socket to use? Obviously it's a single conductor requirement.
stevehertz is offline
Old 13th Aug 2019, 8:56 am   #2
Nuvistor
Nuvistor's Avatar
Default Re: Connector suggestions wanted
These are inline 4 mm sockets, plugs should be easy to find.
https://rover.ebay.com/rover/0/0/0?m...2F282564788134
Frank
Nuvistor is offline
Old 13th Aug 2019, 1:58 pm   #3
David G4EBT
David G4EBT's Avatar
Just a thought:
Given that it's only a receiving aerial, why not put a 'Lorlin' multiway single pole rotary switch in an ABS box with one 4mm socket for the aerial, then the desired number of outlets - four for example - with 4mm sockets & plugs to the various rooms, switched in or out as desired?
Saves plugging and unplugging wires.
Like in the rough sketch below.
Name:	Aerial Switch Box.png
David.
BVWS Member.
G-QRP Club member 1339.
David G4EBT is offline
Old 13th Aug 2019, 3:26 pm   #4
stevehertz
stevehertz's Avatar
Dave, good idea in theory, and I had considered something like that. However, firstly, the aerial splits into just two lines, then one of those again gets split into a choice of two, so a simple 'plug n play' system seemed apt as it's not a 'one into however many', one off choice. Plus I want it to be as unobtrusive as possible where it/they are at almost ceiling height. I don't want to get into mounting boxes etc.
Old 13th Aug 2019, 3:46 pm   #5
Herald1360
Herald1360's Avatar
Go for 2mm?
https://www.ebay.co.uk/itm/Gold-bull...edirect=mobile
NFI etc etc
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 13th Aug 2019, 5:16 pm   #6
stevehertz
stevehertz's Avatar
Originally Posted by Herald1360 View Post
Thanks for rooting that one out, perfect. I just spoke to the guy and the dimensions are OD, so my c2mm diameter core aerial wire will be best suited to the 3.5mm version, which I have ordered. Connections are solder joints which again I prefer. Also, being gold plated they should not give any connection problems. Thanks!
And thanks to everyone who responded, appreciated.
