2nd Apr 2016, 1:55 pm | #1 |
Do you recognize this (allegedly) Mullard radio?
Trying to identify the model of a 5-valve Mullard radiogram chassis that made its way to Australia, possibly from the UK.
At the top left of the dial glass, partially obscured, is the word Hornbrook, which we are given to believe may refer to a re-seller in Yorkshire. Unfortunately the cabinet is no longer around, and the markings on 4 of the 5 valves have been obliterated. The known valve is EBF89. A Plessey capacitor is dated Oct/60. Hoping that somebody may recognize the dial in the attachment. |
2nd Apr 2016, 2:36 pm | #2 |
Re: Do you recognize this Mullard radio?
A picture from the back might help.
The tuning scale shows it was indeed made for the British market. Are you sure it's Mullard? Mullard was basically Philips, and it doesn't look very Philipsy to me. It's also a bit downmarket for Philips - most mid market radiograms would have covered VHF/FM by 1960/61. You normally find EBF89s in 3 valve plus rectifier short superhets - ECH81, EBF89, EL84. A 4 valve setup at that time would have been ECH81, EF89, EBC81, EL84. Hornbrooks appears to be / have been a department store in Leeds. It was normal for such stores to have radios and other electrical equipment made for them by contractors to be sold under a house brand. Partly this was to avoid the Retail Price Maintenance rules, which allowed manufacturers to specify the retail prices for their branded products. |
2nd Apr 2016, 3:30 pm | #3 |
Philips/Mullard usually have a distinctive style of construction. Can you post pictures of the chassis and underside wiring? That will be more conclusive.
2nd Apr 2016, 5:28 pm | #4 |
This certainly does not look like a Mullard, other than it uses their valves. The fact that is AM only and dates from as late as 1960, suggests it was a budget chassis made for the home assembler or for a pared-down, low priced, mono radiogram (probably with a BSR Autochanger) sold via Mail Order or in Furniture/Department Stores. The CIVIC brand was a example of this. Edward
3rd Apr 2016, 2:39 am | #5 |
Many thanks indeed for the replies. The house brand theory may be on the money.
Owner stated Mullard in his post but he may be mistaken. He may be going by the brand on the one valve that is still readable. When I looked on Radiomuseum, I did see some UK models that have a similar style of dial, with rear-lit rectangular station markings. The owner has provided some above chassis photos (below). I can request below chassis shot if that is still deemed useful. |
3rd Apr 2016, 8:20 am | #6 | |
Mark |
3rd Apr 2016, 8:30 am | #7 |
Well it's not Philips/Mullard! There is what looks like a 6AT6 valve presumably driving the output pair (looks like a pair of EL84's). GEC/Sobel and KB were fond of using that valve (also known as EBC90). Really though it's anyone's guess...
3rd Apr 2016, 8:30 am | #8 |
That output transformer looks suspect. Trying to identify the valve line up, it could have a push pull output.
SimonT.
The honesty of imperfection.......... |
3rd Apr 2016, 10:04 am | #9 |
This is the second question about a Mullard radio from "down under"
https://www.vintage-radio.net/forum/...=Mullard+radio
When I die, please don't let my Wife sell my collection for the amount I told her I paid for it! |
3rd Apr 2016, 10:36 am | #10 |
What an odd chassis. If it really is an AM short superhet combined with a push pull amplifier then it's a first for me. I can only think that it was primarily intended to function as a record player with basic radio functionality added almost as an afterthought.
I agree the smaller transformer (output?) looks like a fairly late replacement. Does it have a selenium rectifier? |
3rd Apr 2016, 12:10 pm | #11 | ||
3rd Apr 2016, 12:19 pm | #12 |
I would not have thought that this was a push-pull design in such a basic unit. I would think the valves side-by-side are an EL84 (or equivalent) and an EZ80 (or equivlnet). Both have the similarly sized envlopes. Edward
3rd Apr 2016, 1:53 pm | #13 | |
Under-chassis photo (see post above) shows a rectifier valve socket attached to the power transformer. As to the suggested brand, owner recalls the radiogram having a cardboard card on that he thinks referred to a Mullard model number. |
3rd Apr 2016, 2:05 pm | #14 | |
We had a similar query some time ago about small lettering on the edge of a dial glass, and it turned out to be the dial manufacturer, not the radio. |
3rd Apr 2016, 2:49 pm | #15 |
The dial glass has a very Pye look to me, but I have been wrong more times than right.
3rd Apr 2016, 3:50 pm | #16 |
It's possible that this is actually an (electronically) reasonably conventional 4 valve superhet but with an odd selection of valve types: ECH81/EBF89/6AT6/EL84. There would be some unused diodes there. Maybe the manufacturer designed around whichever valves could be had cheaply at the time, though this attitude was dying out even amongst small manufacturers by 1960.
I think I can see a couple of Hunts Mouldseal caps in there which should be changed if this chassis is going to be used. One cap seems to have been changed already. |
3rd Apr 2016, 5:15 pm | #17 | |
Still doesn't look very Philips or Mullard underneath...nothing like their normal method of construction. The IF transformers are definitely not Mullard/Philips. Also too simple. Looks like it's a circuit that's 'cut to the bone'.
3rd Apr 2016, 7:17 pm | #18 |
It doesn't use any Philips 'black pitch' capacitors, which all Philips sets used until the early 60s.
3rd Apr 2016, 11:40 pm | #19 | |
The owner has subsequently drawn attention to this eBay ad: http://www.ebay.com/itm/Vintage-Civi...-/171794219406 Civic brand with Monarch turntable. Who made Civic? |
4th Apr 2016, 12:14 am | #20 |
Civic was a chain store brand, Currys I think, so the radiogram is identified. The selling price is interesting however.
