16th Jun 2010, 8:26 am | #1 |
10 Volt Primary Winding, Function Of?
Hi all,
this may be a silly question, i apologise in advance but i genuinely don't know. Why is there sometimes a 10Volt winding on a Mains Transformer, the 'other side' of the 0Volt connection. For example:- '10-0-110-220-240' Is/was this to be able to 'make up' the different permutations of Mains Voltages in different countries, so if requiring 230Volts, the connection to the Transformer would be made across the 10-220 Volt tappings? This seems like a logical explanation to me, but am not sure if correct. If someone can enlighten me i'd be gratefull. James. |
16th Jun 2010, 9:39 am | #2 |
Re: 10 Volt Primary Winding, Function Of?
Correct, it gives options of 110, 120, 220, 230, 240, 250. Not just for different countries as mains voltages are not consistent throught the UK 230 +/- 10% is allowed I beleive.
16th Jun 2010, 9:41 am | #3 | |
Andy G1HBE. |
16th Jun 2010, 11:27 am | #4 |
What they said. Its to make it easier to get the correct primary voltage from a fewer number of taps. On one of our machines we need to get an precise 5.5vac secondary on load. To this end the transformer primary is tapped at 10-0-200-220-240 and the secondary at 0-4-4.5-5.0-5.5-6.0. The secondary measured on load with a true RMS meter and the primary and sceondary taps adjusted to give the correct on load voltage. The process can take a long time to complete.
Malcolm |
16th Jun 2010, 6:22 pm | #5 |
Thanks Folks.
Simple when you know, isn't it?!?!?! James. |
16th Jun 2010, 6:36 pm | #6 | |
The weirdest arrangement I ever saw was a transformer designed to give up to 30 or so amps at various voltages between 10 and 20 volts. The taps were marked with the secondary voltages but were actually in the primary winding! Kind regards Dave G0ELJ |
16th Jun 2010, 6:44 pm | #7 |
Just adding a (hopefully unnecessary) cautionary note:
Don't try running the equipment from 10V AC by connecting to the 10V primary taps. The wire it's wound with would not carry the current that would be necessary! |
17th Jun 2010, 12:27 am | #8 |
An interesting variation on the primary theme used to be on some of the small Farnell low power transformers- these had two windings, one 0-110-140, the other 0-110 only. This gave the options of 110V, 220V and 240V.
17th Jun 2010, 1:24 am | #9 | |
17th Jun 2010, 7:24 pm | #10 |
17th Jun 2010, 8:08 pm | #11 |
A pilot lamp would be at mains potential... J.
17th Jun 2010, 10:28 pm | #12 |
UK mains voltage tolerance is -6% +10% of 230 volts nominal.
17th Jun 2010, 10:46 pm | #13 |
Rectified and smoothed gives around 12Vdc, ideal for supplying cooling fans on valve gear.
Don't forget you can use the primary of a large transformer as an auto transformer to feed a smaller transformer. Handy if you need a little boost for a heater transformer. Rob.
We have done so much, for so long, with so little, we are now qualified to do anything with nothing. |
17th Jun 2010, 11:14 pm | #14 | |
18th Jun 2010, 1:20 pm | #15 | |
The 10V tap will be made by bringing out a loop from the winding to the 10V terminal, and then taking back in and continuing the winding. So, although you might be able to disconnect the terminal and separate the two wires, you'll still be left with a winding which is in close proximity to the rest of the primary, with the only insulation being the enamel on the wire. This level of insulation, while it should comfortably pass a 500V test, would NEVER, not even in the deepest darkest days of the AC/DC live chassis heyday, be considered sufficient to protect the user from electric shock. |
18th Jun 2010, 2:19 pm | #16 |
Fair enough!
19th Jun 2010, 1:26 pm | #17 |
I think Dave's weird device was an autotransformer, which has a single winding tapped in way he describes. Quite useful and economical but it provides no isolation as does a normal transformer with separate primary and secondary windings.
Geoff |
19th Jun 2010, 5:29 pm | #18 |
Not weird and not necessarily an auto transformer.
Imagine a transformer whose secondary is wound to give 3.0 volts, tapped to give 2.9v or 2.8v if required. For practical purposes thes tappings are made on the primary rather than the secondary. The taps are marked with the voltage the secondary will produce when that tap is fed with 230v. Rob.
20th Jun 2010, 12:06 pm | #19 | |
Yes, it was definitely not an autotransformer, and the taps in the primary were factory marked. It worked fine, it just seemed an unusual arrangement. I used it at the 12 volts tapping to provide 12 volts AC to run a fridge in my old caravan which would only run on 12 volts or gas, and there was no flue. The 12 volts option was to allow for continued use whilst towing, and took about 10 amps, but it seemed equally happy on 12volts AC when connected to the site mains, as it was a heated 'convection' system. Kind regards Dave G0ELJ |
