11th Aug 2014, 11:54 pm | #1 |
GPO 232 conversion
I have been delving in my cellar and re-discovered my GPO 323 telephone along with a bell set 41. I had been hoping that the no41 bell set could be used with the 323, but from looking at all the useful websites and advise previously given on here I think I am mistaken, and this bell set may only be useful as an extension bell.
I have also realised that the conversion it had many, many years ago actually left it without the induction coil. I have found somewhere where I can buy re replacement coil, but I am wondering whether it would be possible to wire this phone in some way to my 300 series phone and utilise the apparatus in this phone. The 300 (I need to check the exact model, but imagine it is the 310 or 312) has been in daily service for many many years, and has travelled with me to my various homes over the years. Any advice on the use of the two phones would be appreciated. |
12th Aug 2014, 3:00 pm | #2 |
Re: GPO323 conversion
Do you mean a telephone GPO 232?
Regds, Russell W. B. G4YLI. |
12th Aug 2014, 3:33 pm | #3 |
Ah! I was wondering what a 323 was. Seemed odd that a 300-series needed an external bellset. Mystery solved, I think (probably).
12th Aug 2014, 7:23 pm | #4 |
Hello
Ooops! Yes I am mistaken, it is a 232. Can I edit the original post, or can I delete it and begin again? Steve |
12th Aug 2014, 8:02 pm | #5 |
I wouldn't worry. We know what you mean... Are you saying you'd like to use your induction coil-less 232 to answer any calls incoming to your 300 series phone, effectively extending dial, bell, handset and switch-hook functionality of your 300 instrument to your 232?
12th Aug 2014, 11:45 pm | #6 |
Re: GPO 232 conversion
Thanks Russell.
Yes, I think so, it was just something that crossed my mind. It may be that it just isn't possible, or too complex a job to link the two phones. Otherwise I believe (and please correct me if I am wrong) I am happy to buy a replacement induction coil, which I think will make the phone useable. Steve |
13th Aug 2014, 9:24 am | #7 |
Well, it's possible, but it would involve getting at connections in your 300 series instrument that you might not want to tamper with. The incoming pair would parallel across T3 (B wire) and T1 (A wire) of your 232, as normal, then you'd need to run five wires between your 232 and your 300 telephone:
I think I'd be obtaining and fitting a new coil. At least then you'd have a telephone you could use independently without dragging the 300 telephone wherever you go.
13th Aug 2014, 10:43 am | #8 |
I could've sworn I'd written that fifth wire in! Youu'd need a wire from the side of your cradle-switch in your coil-less 232 that DOESN'T go to T2 led to that point in your 300 instrument on the opposite side of the cradle switch to the connection to T11. In other words, where the 30 Ohm anti-quench winding on the ASTIC connects.
13th Aug 2014, 4:18 pm | #9 |
Thank you for the info there, it does sound a little complex and Id end up with a mountain of wiring coming from the 300.
I am right in thinking that if I had the coil on the 232 Id be able to then wire it as an extension phone, just like any other phone? Steve |
13th Aug 2014, 6:01 pm | #10 | |
If your lead colours are different, white goes to pin 2, blue to pin 4 and red to pin 5. That's looking at the plug with the lead towards you, the pins away from you and uppermost, and the detent clip on the right. L to R: 1 N/U and 6 N/U. If you have a bell attached, you might consider replacing the 3k resistor with a solid link.
29th Aug 2014, 7:13 pm | #11 | |
I got my mint Tele 310 from an eBay seller in Belgium! |
