16th Oct 2010, 1:59 am | #1 |
Small beginners guitar amp
Hi all,
A little guitar amp I made up. the pics are from a short text I wrote for newbies to "hand make" it themselves. Original design is from Radio, Television and Hobbies. A now defunct Australian magazine that started in the 20,s and wound up in early 80,s. This design is 1954, sounds superb and is very easy to construct. Chassis is hand made by me, as are transformers and choke. Choke = 10 H @ 150 mA Mains = 285 + 285 volts @125 Ma 6.3 volts CT 2A 5.0 volts 2A Output = 8K CT to 8 ohms Joe |
16th Oct 2010, 11:10 am | #2 |
Re: Small beginners guitar amp
Thats looks a nice little amp,nice work.And you made the TX,s too.Wow!How many watts?Very tidy job,Andy
16th Oct 2010, 11:15 am | #3 |
You have made a great job of that, very proffesional looking
Mark |
16th Oct 2010, 11:30 am | #4 |
I want one!
Very nice work. SEAN
There are only 10 types of people, those who understand the binary system, and those who don't. |
16th Oct 2010, 1:29 pm | #5 |
Really nice job Joe!
Colin Armstrong |
16th Oct 2010, 1:54 pm | #6 |
Yes, very neat work. Is it destined to go in a speaker cabinet or used as-is?
16th Oct 2010, 5:21 pm | #7 |
Probably around 12- that's typical for these valves in the "data sheet" p-p configuration.
16th Oct 2010, 10:29 pm | #8 |
Yeah, around 12 watts ( I didnt bother measuring it). It goes in a speaker box, a single 12" Alnico from the 60,s ( Akai) seems quite efficient ( d#mn LOUD in other words)
there is one modification I made !!, the volume control has been moved to the triode grid, to allow some overdrive without the 12 watts Joe |
18th Oct 2010, 4:32 am | #9 |
Very nice clean layout you have there. I wish my projects looked that sturdy and organized
Cheers, Andrew P.S. Wish I knew how to wind my own transformers |
18th Oct 2010, 6:45 am | #10 |
18th Oct 2010, 9:52 am | #11 |
Craftsmanship of a high order, Joe. You are, I'm sure, justly proud of your quality work.
-Tony |
18th Oct 2010, 11:13 am | #12 |
Very attractively built !
An amp constructed like that can only sound good,it wouldn't dare otherwise. If I had been the designer I would have considered specifiying 6V6's in the original design if the amp was going to get a good hammering. 6BW6's are the same thing of course, but in a B9A envelope. This means they're not so good at dissipating heat and tend to have a short(but fullfilled)life. 12 watts will certainly rattle the windows!
18th Oct 2010, 12:39 pm | #13 |
True - but if the chassis is run out in the open, there'll be plenty of cooling. It's mainly miniature valves in close-packed miniature equipment that suffers. (Although yes, I'd have used 6V6's myself, too).
I have been running a pair of 6AQ5's (B7G version of the 6V6 - talk about fitting a gallon into a pint pot), for 24 years now. I used these because (1) I have some, ex-equipment; and (2) the chassis I was using wasn't big enough for octal valveholders. But these also are running out in the open, and are surviving well! |
19th Oct 2010, 9:22 pm | #14 |
What a nice tidy little job looks so profesional. Bet it can still give a lot of todays smaller guitar amps a run for their money.
Simon BVWS member |
23rd Oct 2010, 8:46 pm | #15 |
Cracking job!
Want one!!
Chroma 04 |
