14th Aug 2020, 12:02 pm | #1 |
Opening Choke on Computer lead.
Is it possible to open the annoying little choke on end of power supply lead ? I need to re-purpose one from an old lead, instead of waiting for a snap together one from China.
John.
My favourite text message "I'll be there in five minutes, if not read again" |
14th Aug 2020, 2:00 pm | #2 |
Re: Opening Choke on Computer lead.
Several methods here: https://vintage-radio.net/forum/showthread.php?t=157796
14th Aug 2020, 3:05 pm | #3 |
Thank you Bill, but not much help, as I need the case and not bothered about breaking the Ferrite core. I expect they are moulded on the cable with no easy way of removing them. I think I will have to order one of the snap together ones from China and wait ... and wait... not ideal when I could have used it yesterday.
John.
14th Aug 2020, 3:30 pm | #4 |
How about pulling the inner cable out and carefully crushing the ferrite then?
14th Aug 2020, 5:23 pm | #5 |
Do you need the choke? Most of these are but a token to EMC.
14th Aug 2020, 5:33 pm | #6 |
Most of them are a complete sleeve/toroid core and are not split. They went on the cable before the connectors were fitted.
Making a split core pair is VERY expensive. The ferrite needs to be ground to a very flat very shiny finish to avoid air gapping. The one-piece ones are just sintered in one go. There's something like a 20-fold difference in manufacturing cost. Often the plastic housing is moulded straight over the core and cable. David
14th Aug 2020, 6:15 pm | #7 |
No, I just need the empty plastic case to hide a small circuit on an audio lead. It should look better than a bulge of heat shrink tubing.
14th Aug 2020, 10:22 pm | #8 |
Ah, now I understand. A slice through one side along the cable axis with a new scalpel should let you peel the shell away, dunking in hot water will help. They are injection moulded and the plastic tends to stick to the original cable, but not too well. Practice on a duffer.
14th Aug 2020, 10:25 pm | #9 |
And a dunk in boiling water will restore it after all the mangling needed to get it off.
15th Aug 2020, 1:48 am | #10 |
I used to collect plastic 35mm film cans for that sort of thing.
-- Graham. G3ZVT |
15th Aug 2020, 7:14 am | #11 |
Might have one John, will check today, yours for postage.
Andy.
15th Aug 2020, 9:23 am | #12 | |
John.
15th Aug 2020, 2:58 pm | #13 |
Here you go John, see pics. Dimensions are 1 1/4" long, 7/8" sq. Drop us your address if of any use. I have four of them.
Andy.
15th Aug 2020, 4:15 pm | #14 |
Thank You Andy that will be great. PM sent.
John. Please close this thread.
