Old 12th Aug 2020, 9:03 am   #1
Bomber county
Bomber county's Avatar
Default Multi leg capacitor polarity
On these old multi leg capacitors which leg is +ve? This one is a 50uF + 50uF and has one broader terminal but no identifying markings, no paint spots or anything. Am I correct to assume that the bigger terminal is a common -ve connection
ID:	213282   Click image for larger version
Bomber county is offline
Old 12th Aug 2020, 10:17 am   #2
ms660
ms660's Avatar
Default Re: Multi leg capacitor polarity
Larger terminal = common -ve
Yellow? terminal = 50uF (inner....HT filter)
Other terminal = 50uF (outer....HT reservoir)
Would be my first thoughts.
Lawrence.
ms660 is offline
Old 12th Aug 2020, 10:29 am   #3
vidjoman
There are what appears to be paint on two of the terminals. Yellow and red on the two on the right. The more separated one looks unmarked. Test with a capacitance meter.
vidjoman is online now
Old 12th Aug 2020, 1:01 pm   #4
Bomber county
No paint spots (unusually) just flux deposits. My meter (Fluke 87) shows "out of range" I have a feeling it is limited to 10uF or something so I can't test them that way.
Next silly question...If I bridge the 2 thinner terminals together will it give me double the marked rating? I can never remember whether its series or parallel.Its only for an experimental/prototype project and will get replaced with a "proper" one if there are signs of life. Circuit specifies 220uf but I have some of these 100+100's and 50+50's lying about.
Old 12th Aug 2020, 1:28 pm   #5
DMcMahon
DMcMahon's Avatar
Yes if the bridge results in a parallel combination, then it will double the capacitance so > 100uF
DMcMahon is offline
Old 12th Aug 2020, 1:59 pm   #6
DMcMahon
DMcMahon's Avatar
I see there are various versions of the Fluke 87, one (V) goes up to 1,000uF and another (IV) goes right up to 50mF (50,000uF) so yours must be a lower spec version.
DMcMahon is offline
Old 12th Aug 2020, 3:16 pm   #7
Bomber county
It's an oldish one, I got it from an MoD surplus sale years ago.
