Old 7th Apr 2021, 5:48 pm   #1
CambridgeWorks
CambridgeWorks's Avatar
Default Radiospares Thermistor TH.1 vs TH-1A info
I wonder if anyone knows the difference between the earlier Radiospares TH.1 and the later TH-1A please. I have their 1967 catalogue listing the TH.1 as equivalent to VA1015. Res cold 930 ohm, Res hot 42 ohm @ 0.3A. The only difference I can see is the TH.1 has what looks like end caps fitted whereas my TH-1A has wires wrapped around either end. Were these onlyith the 0.3A quoted, were these used in 0.3A heater chains on tv or also as ht inrush limiters as well? Reason I ask is I have some I found when sorting.
Thanks.
Rob
Apprehension creeping like a tube train up your spine - Cymbaline. Film More soundtrack - Pink Floyd
CambridgeWorks is offline
Old 7th Apr 2021, 6:24 pm   #2
ms660
ms660's Avatar
Default Re: Radiospares Thermistor TH.1 vs TH-1A info
As a comparison with the suffix, the Brimar/STC CZ range that have the suffix A added are the same electrically, eg: CZ1 and CZ1A are electrically the same but in those the CZ1 is a wrapped wire connection and the CZ1A is an end cap and wire connection.
Lawrence.
ms660 is offline
Old 8th Apr 2021, 9:41 am   #3
CambridgeWorks
Thanks Lawrence. Strange the " A" designation of wire and end caps between the 2 suppliers. Maybe RS ones were from STC.
Rob
Old 8th Apr 2021, 10:10 am   #4
ms660
ms660's Avatar
Rob
Out of interest, there's a note in the Brimar book to say that the CZ1A was only normally supplied to manufactures of equipment (bottom of book page 287):
https://www.rsp-italy.it/Electronics...20-%201958.pdf
Lawrence.
ms660 is offline
Old 8th Apr 2021, 4:18 pm   #5
CambridgeWorks
Thanks Lawrence,
you are always a fountain of knowledge!
Rob
