Old 11th Apr 2021, 7:45 am   #21
julie_m
Default Re: Garrard motor
If it's not a massive difference, could one motor be synchronous and the other a squirrel-cage induction motor (which has to run below synchronous speed)?
julie_m is offline
Old 11th Apr 2021, 3:09 pm   #22
Michael Maurice
Michael Maurice's Avatar
These are pictures of the motors.
This one is the replacement motor.
ID:	231479 Click image for larger version
These are of the original motor.
Forum Moderator
Michael Maurice is offline
Old 11th Apr 2021, 3:56 pm   #23
analogadikt
So my theory gets tossed in the Thames as both the motors are 4 pole, so should turn at identical rpm.
The only suggestion that I can offer now is to connect the replacement motor directly at the wall socket. I have read reply #6 but that did not mention where the "direct to mains" point is, inside the gram cabinet or on the wall.
This is the only suggestion that I have at the moment as it would confirm if there is any issue with the replacement motor or the supply point in the gram.
Edit : What is the voltage rating stamped on the bottom bearing of the replacement motor? Dual voltage or single voltage?
Regards,
Anwesh
Anwesh
analogadikt is offline
Old 11th Apr 2021, 5:22 pm   #24
Michael Maurice
Thanks Anwesh, the motor is stamped 110 200-250V, 40 - 80 Hz he original motor is also dual voltage. I may try another type later tonight.
Forum Moderator
Old 17th Apr 2021, 11:08 pm   #25
Trevor
Garrad motors from the later period ran synchronous by virtue of the fact that they were fitted with a ceramic circular magnet on the rotor . when the motor was required to do some work it then relied on the caged roter
This being the case the stepped pulley would be of a different diameter to the earlier
motor
Trev
Trevor is offline
Old 18th Apr 2021, 9:17 am   #26
analogadikt
motor
Trev
That is the Synchro-Labâ„¢ motor which came much later and was seen on the SL, AP series automatic turntables.
The original and the replacement motor tried here are pre 1960 pure induction motors.
Regards,
Anwesh
Anwesh
Old 18th Apr 2021, 12:45 pm   #27
nicam49
Hi, I've not looked back to check... but wasn't there a thread in the not too distant past where the 2 motor windings were connected out of phase so the mag field wasn't of sufficient strength..... ��
nicam49 is offline
Old 20th Apr 2021, 9:55 am   #28
Tractorfan
Tractorfan's Avatar
Smile Re: Garrard motor
I have a Garrard RC80 autochanger.
The motor would run fine from cold, but then it began buzzing and getting hot after a time.
I found that one of the coils was going dead short when it warmed up.
Fortunately, I was able to strip it down and send the two coils off to Ed Dinning to be rewound. He did a splendid job, and it runs lovely now.
Thanks Ed!
Cheers, Pete.
"Hello?, Yes, I'm on the train, I might lose the signal soon as we're just going into a tunn..."
Tractorfan is offline
Old 20th Apr 2021, 7:36 pm   #29
Ed_Dinning
Hi Pete, thanks for the praise. In the particular motor being discussed here the coils had been wound on a jig and the fitted to the motor stack, sdo without trying to make a jig it was a no-no
Ed
Ed_Dinning is offline
Old 20th Apr 2021, 9:46 pm   #30
Michael Maurice
You were right. I reversed the connections to one of the coils and it started working perfectly.
Now to the next horrible one a Beogram 1000.
Forum Moderator
