Old 4th Aug 2016, 11:36 pm   #1
Wendymott
Wendymott's Avatar
Default Dual Tone generator for SSB
Hi Peeps... Thought you might be interested in this little box..a Two tone sine wave generator for setting up SSB exciters and PA's. I cannot claim originality for the schematic, as it was on the net.. but it has been modified. The box was scratch built from 2.5mm Styrene sheet.
To ensure a reasonably linear sinewave the lower base bias resistor is trimmed with a parallel resistor, depending on the gain of the device. A series resistor is also placed in the VR top leg to equalize the outputs at max rotation.
Name:	Bare front panel.jpg
ID:	128283   Click image for larger version
Name:	Case carcase.jpg
ID:	128284   Click image for larger version
ID:	128285   Click image for larger version
ID:	128286   Click image for larger version
Name:	Two tone test Gen V2..jpg
Should get out more.
Regards
Wendy G8BZY
Wendymott is offline
Old 5th Aug 2016, 8:17 am   #2
Herald1360
Herald1360's Avatar
Default Re: Dual Tone generator for SSB
Do let us know what your third order IMD is like from the finished TX.
(Many boring hours spent chasing better than 35dB down on the individual tones on solid state "linear" amps in the early '80s)
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 5th Aug 2016, 10:37 am   #3
Wendymott
Wendymott's Avatar
Chris.. it will be a while yet...something not quite right in the modulator/audio preamp..its seems to be losing the 1380 hz...and I know the bandpass filter is ok 300 - 3 khz.
Regards
Wendy G8BZY
