13th Sep 2014, 5:58 am | #1 |
What is this component called?
Greetings,
First post here, total noob. Bought a pair of Ericsson BCI 339 telephones, excited to restore them. One is working well. The second works after comparing the wiring and rectifying a simple inversion — but the sound is a tad crackly and muffled. Not the fault of the earpiece (swapping them changes nothing). The "good one" has one component that the "bad one" lacks. I know nothing about electronics, and I'm sure most of you will know whether that small block that says "50-A" on the left side is a capacitor, a resistance or a pizza. Would love to buy that component and wire it in. Thanks in advance for any insights! Wishing you all a beautiful weekend |
13th Sep 2014, 10:13 am | #2 |
Re: What is this component called?
Don't know this phone at all, but the component looks like a fairly hefty inductor. Am I right in thinking that it only has two connections?
Les. |
13th Sep 2014, 11:55 am | #3 |
This is little more than a guess but that mystery part may be a buzzer.
As for the poor sound quality, the first thing I'd rule out is the microphone (or 'Transmitter,' to use the correct terminology). Try swapping those as you did with the earpieces ('Receivers'). Good luck Joe |
13th Sep 2014, 10:23 pm | #4 |
I'm no electrician, but it looks like a 500V 2mf capacitor.
Wrong part |
13th Sep 2014, 11:08 pm | #5 |
Thank you all so much for your replies!
@lesmw0sec Yes, there are two contacts that go straight to the line terminals. @ThePillenwerfer A buzzer? This phone does buzzes, the other doesn't… Let's open it up and ring the number… Yes! That component buzzes! Terrific, thank you for solving that mystery. On the "bad one", tried removing then swapping the transmitter as you suggested, but the crackle + distant tone persists. Attaching a close-up of the buzzer and a shot of the same model in cream. If I wanted to add a buzzer to the other phone, is that something I need to cannibalize from another old phone, or is that piece easy to buy? Cheers! |
14th Sep 2014, 5:13 pm | #6 |
Try cleaning/spraying contact cleaner into the 'cradle' switch; not unknown for these to give a noisy connexion.
The buzzer is, most likely, not essential and probably included (in the phone which has one) because it was once an extension in, say a bosses office, and the secretary who had the main phone had an instrument with an extra button to 'buzz' the extension. For an idea of how this worked look up British P.O. telephones 'Plan 1A' . |
14th Sep 2014, 7:57 pm | #7 |
Just a quick comment: these phones were not designed to have an internal bell, a typical installation would have a separate wall mounted bell. The buzzer would be fitted where an audible ringing signal was wanted from the phone unit itself. I have converted a number of these (ex-French PTT) phones and there is room inside for a small bell that can be found in plenty on the 'net.
Robert |
14th Sep 2014, 8:20 pm | #8 | |
14th Sep 2014, 10:46 pm | #9 | ||
There's still a tiny bit of crackling —don't own any contact cleaner, will look for some. By the way are there other contacts / components that are particularly good to clean? Quote:
Now for a juicy detail. At first I thought that the dials didn't work. Then the Wikipedia segment about pulse rates told me that Sweden and New Zealand were the two exceptions to the standard dial (0 at the bottom, 1 at the top): it went 0 at the bottom, then 1, 2, 3… I tried translating phone numbers (for instance 548-5487 becomes 562-5623), and the dial worked! At the moment my "translator" is pieces of painter's tape (see picture). But I've ordered one rotatone unit in the hope of converting the pulses to tones… Hope it works, we'll see! |
15th Sep 2014, 2:51 am | #10 |
Glad to hear that it's progressing.
The dial contacts may well benefit from cleaning as well. I'd advise against using sandpaper on them as they are quite small and relatively delicate. In the absence of contact cleaner, put some alcohol on a bit of card and rub that between them. I attach a picture of the back of a dial with the contacts circled in red. This is a British one but yours will probably be very similar. - Joe |
15th Sep 2014, 3:43 am | #11 |
As to the unidentified component, it might be an artificial ringer.
The reason might be to make the phone's impedance look like one with a ringer. In Canada, in past years, the telephone company could detect the number of phones on a line by the return kick on a meter, after a voltage was applied. You might measure the inductor part for resistance and see if it is the same as another ringer using a 2 uFd capacitor.
Steve Dow VE7ASO |
15th Sep 2014, 8:36 am | #12 |
Graham, thanks for that - memory playing tricks again. As an aside though I'm amused to think P.O. Tel could consider connecting phones in parallel officially 'a plan' !
15th Sep 2014, 10:08 am | #13 | |
15th Sep 2014, 7:43 pm | #14 |
@ThePillenwerfer Thank you for the contact cleaning tips and the diagram!
@radiotechnician Thank you — yes, it is a buzzer. |
15th Sep 2014, 10:41 pm | #15 | |
Ian |
16th Sep 2014, 12:55 am | #16 | |
The power question is a non-issue as the rotatone also feeds on the line (it sits inside the phone). One possible issue with the Dialgizmo, but not sure: my phone line understands pulse. The rotatone eliminates the pulse so that the phone line only receives the tones, which is what I want, as feeding both pulses and tone on the line would probably not work. It's unclear from the Dialgizmo website if it also suppresses the pulses (they say it's specifically for VOIP lines). If so, that's a good option… and cheaper than rotatone. |
16th Sep 2014, 1:50 am | #17 |
The Dialgizmo suppresses the pulses as well.
I've never had to use either but if I did I'd go for the 'gizmo. You need a Rotatone for every 'phone but one Dialgizmo can work with several. At least that's my understanding. - Joe |
16th Sep 2014, 8:59 am | #18 |
Thanks guys, the rotatone was ordered a few days ago but for the next phone I might try the dialgizmo.
19th Sep 2014, 7:39 pm | #19 |
Hi
A little late popping in here, NZ and the city of Oslo (Norway) are the only remaining places with reverse dial. Sweden has their own, 1 pulse = 0 2=1 etc. The buzzer may not be easy to get, but it was used pretty small buzzers in Ericofones (Cobra) in Norway and Sweden. Maybe a miniature ringer for the Western electric prisess, or Automatic Electric Starlite may fit in too. The noise may as mentioned over be the carbon transmitter, try whats happening with a 220 ohms resistor shunting the transmitter. Dial pulse rates was commonly 10 pulses pr sec, but the double has been used a few places. Brake make ratios are usually OK even across standards. dsk |
